Forum » Pomoč in nasveti » Microsoft .Net Framework Update težava
Ozric ::
Windowse XP 64 SP2 nikakor ne morem posodobit s sledečim update-om Microsoft .NET Framework 3.5 Service Pack 1 and .NET Framework 3.5 Family Update (KB951847) x64. Hvala za nasvet.
- spremenil: Ozric ()
gorenjc ::
Ja, z microsoftovimi popravki so včasi sami križi in težave. Največji problem je pa reševati probleme s popravki za net.framework. Tole je iz foruma od microsoft-a.Težava sicer pri visti, pa vendar: http://social.answers.microsoft.com/For... Opis napake bi moral biti tudi v logu na mašini KB951847.log
Ozric ::
Hvala! Uporaben link,problem pa rešen takole...
Step 1: Use .Net Framework CleanUp Utility
1. Please download the tool from the following link:
http://cid-27e6a35d1a492af7.skydrive.li...
Please Note: Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
2. Please save the zip file (dotnetfx_cleanup_tool.zip) from the above link to the local Desktop and extract it.
3. Double click cleanup_tool.exe to run the tool.
4. Please follow the instructions given.
In the "Product to cleanup:" box, please select ".NET Framework - All versions".
5. Click "Cleanup Now" button.
6. Restart the computer.
Step 2: Manually downloading and installing Microsoft .NET Framework 3.5
Please note: The size of Microsoft .NET Framework 3.5 and .NET Framework 3.5 Service Pack 1 is a little big. Your patience to download the update is much appreciated.
1. Click the following link:
http://download.microsoft.com/download/...
Microsoft .NET Framework 3.5 Family Update
Tac20 ::
Meni prav tako noče namestit te posodobitve, če pa ročno downloadam file pa napiše pri extractu da je file corrupt, lahko nekdo poizkusi, če mu napiše isto?
Hvala
Hvala
| » | Microsoft .NET Framework 4 - Napaka ?!Oddelek: Pomoč in nasveti | 1650 (1433) | SanAndreas |
| » | Težava z .NET 3.5Oddelek: Pomoč in nasveti | 1306 (1094) | NeMeTko |
| » | Noče mi namestiti Nvidia Control PanelOddelek: Pomoč in nasveti | 952 (885) | gamemen |
| » | Ne morem naložiti driverjev.Oddelek: Pomoč in nasveti | 1482 (1363) | wildjoc |
| » | Crashanje programovOddelek: Pomoč in nasveti | 1266 (1059) | kratos |
