Forum » Igre » problemi pri igri gta iv
pintarj ::
Sem nov na forumu in imam vprašanje. Naložil sem gta 4.Ko pa hočem igro zagnati mi javi napako. Zanima me ali mi lahko da kdo kakšen nasvet kako napako odpraviti.
pintarj ::
GTA IV TLA ERROR: DD3D30
Ali mogoče veste kaj bi lahko bilo narobe?
GTA IV FATAL ERROR: DD3D30
(POPRAVEK)
(POPRAVEK)
- spremenil: pintarj ()
Rotaidal ::
Si spremenil resolucijo?
Kaj pa to si videl?
1. RMN20 Windows Vista: Need to have Service Pack 1 or higher to proceed.
2. RMN30 Windows XP 64 / Server 2003: Need to have Service Pack 2 or higher to proceed.
3. RMN40 Windows XP: Need to have Service Pack 3 or higher to proceed.
4. DD3D50 D3D Error - DirectX 9 video card required
5. TEXP110 D3D Error - Failed to create texture - Please restart the game
6. DWIN20 D3D Error - Failed to query memory. Please re-start the game.
7. DD3D10 D3D Error - Please re-boot your system
8. DD3D10 D3D Error - Please re-boot your system
9. DD3D30 D3D Error - Please re-boot your system
10. DWIN30 D3D Error - Please re-boot your system
11. DD3D20 D3D Error - Please re-install the game and/or re-install DirectX
12. DWIN10 D3D Error - Please restart the game
13. DD3D60 D3D Error - Shader Model 3.0 or higher is required
14. DD3D70 D3D Error - Unable to retrieve D3D Device. Please re-boot your system
15. GPUP10 D3D Error - Unable to retrieve D3D Device. Please re-boot your system
16. TEXP20 D3D Error - Unable to retrieve D3D Device. Please re-boot your system
17. TEXP30 D3D Error - Unable to retrieve D3D Device. Please re-boot your system
18. TEXP80 D3D Error - Unable to retrieve D3D Device. Please re-boot your system
19. DD3D40 D3D Error - Unable to retrieve device capabilities. Please install latest video card driver and/or re-install DirectX
20. TEXP10 D3D Error - Unable to retrieve device capabilities. Please install latest video card driver and/or re-install DirectX
21. DD3D80 D3D reset failed - Please restart the game.
22. STRB10 Failed to delete file - Please re-boot your system
23. RMN10 Failed to read file - Please re-boot your system
24. STRM10 Failed to read file - Please re-boot your system
25. STRM20 Failed to read file - Please re-boot your system
26. BNDL10 Failed to write file - Please re-boot your system
27. STBF10 Failed to write file - Please re-boot your system
28. VOIC10 Fatal voice chat error - Please restart the game
29. RESC10 Out of video memory - Please re-boot your system
30. BA10 Out of virtual memory - Please re-boot your system
31. EA10 Out of virtual memory - Please re-boot your system
32. TEXP60 Unable to create color render target - Please re-install DirectX and/or install the latest video card driver.
33. TEXP70 Unable to create depth render target - Please re-install DirectX and/or install the latest video card driver.
34. AE10 Insufficient Memory to Start Game - Please close some applications and restart the game
35. PC10 Unable to retrieve D3D Device - Please reboot your machine or reinstall your display driver
36. TF10 Unable to write to disk - Please restart the game
37. WS20 InitWinSock failed - Please re-boot your system and/or re-install the game
38. WS30 InitWinSock failed - Please re-boot your system and/or re-install the game
Kaj pa to si videl?
pintarj ::
resolucijo sem spremenil od najmanjše do največje in še vedno ne gre, tud računalnik sem zagnav ponovno in še vedno ne dela. A je možnost da gta4 ne dela v windows 7?
DaVidQ ::
Meni dela povsem lepo in brez problemov.
EDIT: win 7 build 7600 RTM
- spremenil: DaVidQ ()
Valvoline ::
Kšno grafo maš. Gta4 zahteva grafo z shader model 3.0
Zakleni frekvenco osveževanja(refresh rate lock) na 60hz za gta4 v ati CCC ali nvidia CP.
- spremenil: Valvoline ()
geek93 ::
probaj nastavit kompatibilnost na windows xp service pack 3.
Ko sem še jaz igral GTA IV se mi je igra ful zatikala, pa sem nastavil na windows xp sp3 compatibility in je lepo šlo.
Mentalist ::
Jaz mam pa problem pri GTA IV. Igra se včasih zatakne, je original računalnik je tudi dovolj močan, dal sem tudi one compatibility pa nič, kaj še je lahko.
Lool.
Rotaidal ::
Lahko je več stvari. Gonilniki, dx, zapacan sistem, pregrevanje...
- spremenil: Rotaidal ()
virtuality ::
am mislim da ni problem v strojni opremi ali mi lahko poveš kateri OS maš? Če imaš Windows XP Service Pack 2 potem ga moraš upgradat na Service Pack 3 in bo normalno delalo. Tko je tudi že meni naredilo isto ERROR potem sem upgradal na SP3 in dela normalno
Mentalist ::
Windows 7
I7 920
3GB rama
Sapphire radeon 4870
Men ne kaže nič errorjev samo tak štekne dostikrat pa je malo moteče, mam tudi patch sem naložil 1.5.0.0. al kak je že pa je isto:S Pregrevanje mislim da ni, ker ostalo dela normalno DX je tudi mislim da 10 bom pogledal gonilnike pa nalagam zdaj.
No zdaj pa v GTA IV črna slika neka.
I7 920
3GB rama
Lool.
- spremenil: Mentalist ()
MihaMi ::
Sem kupil GTA IV: EFLC(Episodes from Liberty City) in mi zelo šteka. Vse nastavitve sem dal na minimum in še vedno je štekalo. Ne vem kaj naj naredim. FPS:60 Specifikacije: AMD Athlon II X4 640, 3.01 GHz, 1,75 GB RAM, Windows XP Service pack 3. Hvala vsem za vnaprej.
| » | Directx problemOddelek: Pomoč in nasveti | 1845 (1522) | LeeWai |
| » | paypal pomoč!Oddelek: Pomoč in nasveti | 2291 (2161) | StratOS |
| » | Gothic 2 ne dela zaradi novih ATI-jevih driverjevOddelek: Igre | 1521 (1386) | nosferatu666 |
| » | DVD-RW, DVD+RW, DVD-RAM-->HELP ME!!!Oddelek: Pomoč in nasveti | 1819 (1476) | [Eraser] |
| » | CATALYST 3.6Oddelek: Programska oprema | 9016 (8501) | freejack |
