Directx problem
Directx problem
ShadowX ::
Stvar je taka. V dxdiag mi piše da imam directx 11, vendar ne morem zagnati igrce, ki potrebuje directx 9. Torej, potegnem directx 9, instaliram, še kar ne morem. Potegnem end user iz MS strani tudi to inštaliram a brez uspeha. Kar lahko igram so samo igre z 10x ali več.
driverje sem odstranil ter ponovno naložil, nič. V Catalystu mi tudi 3D slike ne pokaže.
Kaj lahko še storim?
gorenjc ::
Kakšen je OS?
ShadowX ::
windows 7
grafa 4890
gorenjc ::
Directx 11 bi moral biti kompatibilen nazaj. Se pravi igrice, ki delajo pod directx 9, bi morale delati tudi pod višjo verzijo. Ker ima, kolikor vem, windows 7 ( pa tudi Vista) svoj nabor knjižnic za directx 9, se bi lahko probalo z nadgradnjo teh. Na microsoft-ovi strani je program za update.
Link: http://www.microsoft.com/downloads/deta...
ShadowX ::
Prvič gre skozi in mi javi da je novejša verzija že gor na kompi(nato mi jav win da program ni pravilno nameščen) in še 1x dam skozi, potem pa javi slednje:
An internal system error occured. Please refer to DXError.log and Directx.login your Windows folder to determine problem.
iz DXE
[10/26/09 02:55:21] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 1269, function: CabCallback
    Failed API:		DeleteFile()
    Error:		(5) - Access is denied.
    Unable to delete C:\Users\Tamal\AppData\Local\Temp\DXB46B.tmp\d3dx9_27.dll.
[10/26/09 02:55:21] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 5714, function: DirectXUpdateInstallPlugIn
    Failed API:		SetupIterateCabinet()
    Error:		(32) - The process cannot access the file because it is being used by another process.
    Unable to iterate through D:\Igre\CITYLI~1\DirectX9\Aug2005_d3dx9_27_x64.cab. The file may be damaged.
[10/26/09 02:55:21] module: dsetup32(May 31 2007), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
    DirectXUpdateInstallPlugIn() failed.
[10/26/09 02:55:21] module: dsetup32(May 31 2007), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[10/26/09 02:55:25] module: dsetup32(May 31 2007), file: dsinline.h, line: 302, function: DXRemoveFile
    Unable to remove C:\Users\Tamal\AppData\Local\Temp\DXB46B.tmp.
[10/26/09 02:55:25] module: dsetup32(May 31 2007), file: inline.h, line: 220, function: CleanUpDirectory
    Unable to remove: C:\Users\Tamal\AppData\Local\Temp\DXB46B.tmp\d3dx9_27.dll which is locked, reason = 5.
gorenjc ::
Tukaj http://www.tomshardware.com/forum/185-6... je podoben primer.
V tem forumu svetujejo namestitev DirectX Redistributable August 2009 9.27.1734 http://www.microsoft.com/downloads/deta...
ShadowX ::
ne, tudi to ne deluje. :(
mi preostane samo še 1x winse posnet?
gorenjc ::
Če je problem samo z Directx 9.0, potem vsaj jaz ne bi šel še enkrat nameščat windows-ov. B bilo dobro še malo pobrskat po Google-u al pa po forumih.
Pri kateri igri je pa konkretno problem?
ShadowX ::
pri vseh. :) pač, tiste ki rabijo dx9, npr. hawx lahko igram, ker ima podporo dx10.
edit: probal sem pa že tak vse, vsako instalacijo, vse kar je v povezavi z dx9. Ne vidim drugega izhoda kot s formatiranjem c diska. Upam da bom s tem popravil dx problem.
  • spremenil: ShadowX ()
1metek ::
kero verzijo catalyst maš?
jest sem se vrnu nazaj na visto ker kar folk okol govori sploh ni res men tut 7 nagaja neki cajta špil dela pol mi ne dela pol spet dela pa non stop mi spreminja barvno shemo internet mi vn meče itd skratka sedmica sucks vista rules
  • spremenil: 1metek ()
Senitel ::
Kristus... Če imaš DX11 imaš DX10, če imaš DX10 imaš DX9, če imaš DX9 imaš DX8, če imaš DX8 imaš DX7,... DirectX ima samo par dll-jev: d3d11.dll, d3d10_1.dll, d3d10_1core.dll, d3d10.dll, d3d10core.dll, d3d8thk.dll (DX8 in vse nazaj), če si up to date. Potem so tu še d3dx9_*.dll, d3dx10_*.dll, d3dx11_*.dll in D3DCompiler_*.dll.
Katere DX9 igre ti dejansko ne delajo?
Misliš, da je enostavno možno, da cel fallback DX-u ne dela, kar bi verjetno že kdo opazil? Ali pa je pač špil nesposoben in hoče za brez veze pogruntat kater DX je na mašini.
LeeWai ::
Hvala Gorenjc,
sem meu isto težavo, fallout las vegas mi ni delu na dx11 je hotu dx9, sm posneu un fajl k si dau link on micosofta in dela.
Titan Quest (strani: 1 2 )
Oddelek: Igre
8510198 (329) Gregor459
DirectX - an internal error occured
8934 (885) amigo_no1
ALKYLOG
Oddelek: Igre
61052 (942) SomethingEls
problemi z Vista SP1
81560 (1323) CyberAD
Hitman--bloodmoney noče delat
Oddelek: Igre
81580 (1391) acroni
