Gothic 2 ne dela zaradi novih ATI-jevih driverjev
strictom ::
pred kratkim sem s www.ati.com/support potegnil nove driverje in mi gothic 2 ne dela več, starih driverje pa ne mislim nalagt ker so zanič
aja grafo mam radeon 9200
plz help!!!!:P
stefanc ::
strictom ::
amnn... ni
vseeno hvala!
stefanc ::
Mogoče bi pomagal reinstall Gothica
Po inštalaciji Gothica sem zamenjal grafično in mi ga potem nikakor ni uspelo pognati.
Pa še inštalacija ni ravno med najhitrejšimi, če se prav spomnim...
strictom ::
ahh, budalo jaz
na re-install sploh pošudiral nisem;((
hvala!!!
LP!
strictom ::
:'( mah... san ni pomagalo, zgleda da bom mogu obupat nad gothic 2
nosferatu666 ::
Vsekakor bi pomagalo, če bi povedal, kaj oz. kako ti ne dela.
Se ne zažene, se obesi....?
gumby ::
namesti stare driverje nazaj...
strictom ::
evo vam to mi napiše:
X: XD3D_InitPerDX: Can't Create D3DX Context ! Error: DDERR_UNSOPPORTED
nosferatu666 ::
Stric Google pravi tole:
Fix for "My ATI card won't run Gothic II because I keep getting a X3D_Yadayada error message every time I start it" and "Gothic II suddenly stopped working with my ATI card and I keep getting X3D_Yadayada error message":
1) Make the setting gotic2.ini changes as mentioned above.
2) Open up display properties.
3) Click "Advanced"
4) Click "ATI Direct3D"
5) Click "Compatability Settings" (at the bottom"
6) Click "Reset Defaults"
7) Click the circle next to "Use W Buffer"
8) Click "Apply"
9) Run Gothic II
That should eliminate the problems with the X3D. Do not enable "Use 32-bit Z buffer" and "Use W buffer". I didn't test it with "Use 32-bit Z" only clicked so someone needs to test it (my game isn't broke now and I don't want to try ). If you have both 32-Bit Z and W buffer selected you will seemingly randomly get the X3D error.
Skratka, W buffer. Če še vedno ne bo šlo, izklopi AA in AF ter poglej v .ini.
Elex (strani: 1 2 3 4 5 6 7 8 )
Oddelek: Igre
39198621 (30020) oo7
Gothic 2 Gold edition
Oddelek: Igre
294673 (2672) LINKO
Original igro zaženem, a se ne zgodi nič..
Oddelek: Igre
172454 (2069) Cold1
Gothic2 walktrough
Oddelek: Igre
51232 (1206) karafeka
CATALYST 3.6
Oddelek: Programska oprema
169016 (8501) freejack
