Ugodno do DSLR Sony Alpha 330 za 399€
BALAST ::
Ker spremljam akcijske cene v tujini, sem našel res ugodno ponudbo za DSLR Sony Alpha 330, res da je na Ebay.de, ampak pošiljajo tudi v slovenijo za 12€. Več pa na Ebay povezavi. 399€ +12€ poštnina. Gre pa za zelo dober fotoaparat z odličnim LiveViewom, HDMI, dobrim objektivom in kar je važno tudi odlično izdelavo.
Uradna stran Sony
Sony Alpha A330: Specifications
Resolution: 10.2Mp
Sensor size: 23.6x15.8mm
Sensor type: CCD
Max. image size: 3872 x 2592
Aspect ratio: 3:2, 16:9
Focus system: TTL phase detection
Focus points: 9
Crop factor: 1.5x
Lens mount: Sony A, KonicaMinolta A
File type: JPEG, RAW
Sensitivity: ISO100-3200
Focus types: Single, continuous, automatic, manual
Metering system: 40 segment honeycomb SPC
Metering types: Multi, centre-weighted, spot
Exposure compensation: +/- 2EV in 1/3 step increments
Shutter speed: 30sec-1/4000sec
Frames per second: 2.5fps (2fps in live view)
Flash: Built-in, hotshoe
Flash metering: TTL, GN 10 (ISO100)
Flash sync speed: 1/160sec
Image stabilisation: Image sensor shift system
Integrated cleaning: Charge protection coating on low pass filter, sensor-shift system
Live view: Yes
Viewfinder: Optical fixed eye level penta-Dach-mirror
Monitor: 2.7in LCD 230,400dot
Media type: Memorystick, SD, SDHC
Interface: USB 2.0, HDMI
Power: Infolithium
Weight: 490g
Alpha 330 na youtube.
Še par opisov v angleščini. Klik, Klak
V sloveniji je pa kar 100EUR vec.
  • spremenil: BALAST ()
marko20 ::
mislim, da si se malo zmotil
pri Enaa stane 499EUR
http://www.enaa.com/oddelki/foto/izd_26...
Nov D-SLR (strani: 1 2 )
8832542 (20807) BigWhale
Canon EOS 550D
4317001 (13698) BlueRunner
PRAKTICA DVC 5.2 FHD
Oddelek: Zvok in slika
73862 (2830) blackbfm
Kateri DSLR kupit?
92595 (2522) bluefish
Rotiranje fotk
202693 (2405) Ziga Dolhar
