Gigabyte - GEFORCE 4 = problem ??
pajek ::
Zanima me ( nekje sem prebral, samo nevem kje več :\ ), da GIGABYTOVE PLOŠČE IN GEFORCI 4 delajo neke probleme - samo nevem KAKE ? ... any ideas ?
no konkretno me zanima če bo na moji GIGABYTKI ( GA-7VTX-flaširani z zadnjim biosom ) in pa bodoči grafikulji - XFX GEFORCE 4 Titanium 4200 64Mb DDR DVI TvOut ... DELALO VSE BREZ PROBLEMU ? :\
... in nasplošno če se pojavljajo kaki problemi, vaše izkušnje z čipi GEFORCE 4 Titanium 4200 v navezi z GIGABYTE matičnimi ??
tenx ... lp
--- A M D ---
the_unborn ::
vem samo da enim dela in drugim ne...jst bom kar igral na sreco in videl kaj bo
pajek ::
ja..hm..to mi ne pomaga glih veliko .... ;(
kaj so določeni modeli plošč ... ali KAR NE DELA ALI DELA ?
kaj ima kdo v navezi z GA-7VTX ... in če ima naj se tu razpiše in še KAKO NE DELA?, je niti NE zazna GRAFIČNE ALI DELA NESTABILNO ... ali :\
tenx ...
the_unborn ::
uporabi search pa bos nasel dosti tem o tem;(( , baje novejse verzije nimajo vec problemov
pajek ::
obstaja kje spisek..link?, na katerih GIGABYTOVIH verzijah matičnih DELA in na katerih NE-DELA ... npr .. na GA-XXX ??
tenx ...
Maximus ::
Poglej na gigabytovi strani, mogoce tm kj pise
LP!
kuglvinkl ::
Tole sem našel tukaj:
Quite a few people have reported problems with using a GeForce4 card in a Gigabyte GA-7VRX or GA-7VRXP motherboard.
A good number of 1.0 versions of this motherboard barely worked at all with GeForce4 cards. Stability was unheard of.
The 1.1 version of this board would sometimes work and sometimes not work. Odds are better of getting a functioning board, but if you have this version of the board and your GeForce4 card does NOT work, increasing the VCore voltage by +7.5 in the BIOS can help. The side effect of this can lead to higher temperatures causing a whole new batch of problems. Better cooling solutions (like a Volcano7 or Coolermaster Heatpipe AT MINIMUM) can pacify the heat issues, but I feel that long term usage at this high of a voltage will cause inevitable failure.
After calling Gigabyte (you would think that they should call me knowing that they sent me a few hundred motherboards with a "known issue") because I was growing very tired of all of the tech calls I was receiving about the board's stability issues with the GeForce4 card, I was told that the boards needed to be reworked. Older boards were being "updated" by adding a 4.7uF capacitor between the VR at Q36 and a spot on the board where a surface mounted capacitor could go (but isn't installed) at C139. A new revision (2.0) with a resistor (labeled R833) added has already in production and being shipped.
I've already tested the 2.0 version of the board with a PowerColor brand Ti 4200 128MB DDR and things do seem to be considerably better, but I think the first sample motherboard I pulled off of the shelf has a whole bunch of different isses (getting registry errors with known good parts in a known good Windows install. Will try again this weekend with all different parts as well as a different 2.0 board).
This is a 7VRXP revision 1.1 that has not been modified. This is just above and to the left of the Northbridge fan if you look at the board as it appears in the motherboard manual.
This is a 7VRXP revision 2.0. Notice the resistor added between the would-be capacitor at C139 and the voltage regulator at Q36. Apparently, this is all Gigabyte needed to add to address their problems.
If you contact Gigabyte at 626-854-9338 you can obtain an RMA # to have your board reworked. To my knowledge, they are not replacing motherboards for newer revisions. If you are adamant about getting your board replaced and not reworked, you should contact your vendor, but please do not expect the vendor to go beyond their normal RMA policies to rectify this issue. They just sell the board. They will end up having to send back a number of motherboards for reworking just like the end users.
I must say that Gigabyte is generally.. typically.. a good company that makes good product, but the GA-7VRX motherboard was a plain and simple mistake. I have worked with many Gigabyte motherboards and complete Gigabyte barebones systems and RARELY have I encountered a single issue. But the fact that this board was sold to the general public with such an obvious flaw and that Gigabyte to date still has no mention of the issue on any of their web site does not sit well with me. Over time, I may forgive them. ;-)
Tech on my fellow techno-dweebs! jonnyGURU 07/10/2002
Edited once I woke up from not sleeping after three days 07/11/2002
problem z hpj g72 sam se ugaša,pozneje se noče prižgat
5963 (910) Samson
rabljena graficna mx400 - zakaj ne dela?
111683 (1482) dexter_II
Asus A7S333 -> voltaža
91512 (1433) m.i.h.a.
Dvo-procerska plata
171820 (1608) nodes
Gigabyte 7vrx + WinFast GF4 A250 LE TD - PROBLEM
201700 (1500) Buggy
