Forum » Programska oprema » Photoshop problem
Photoshop problem
BuzzFuzz ::
Ne uspe mi shranit slike resolucije 1280x1024 v format vtf.
Error: Error: ..image width is not a power of two.
vtf?
noraguta ::
Valve Texture Format
(Redirected from VTF)
The Valve Texture Format (VTF) is the proprietary texture format used by the Source engine.
VTF files are just one layer in the Material System. VTFs ("Textures") can only be applied to Geometry via a VMT ("Material") File. VMTs can assign several VTFs to the same surface, and specify which Shader and Shader Parameters to use when rendering the textures.
VTF files can be compiled from TGA images using the Source SDK Tool Vtex, or a third-party VTF utility. VTFs and VMTs are stored in subfolders of the game_dir/materials directory.
To be valid, all textures must have dimensions that are powers of two (see the note about mipmaps under Storage capabilities below):
2
4
8
16
32
64
128
256
512
1024
2048
4096
RuN ::
Drugače povedano:
Če probaš shraniti v razmerju 2048x1024 ali 1024x512 pol bi šlo oz. mora biti razmerje 2:1
RuN ::
V format al samo dodaš končnico??
Če imaš nameščen Plug-in in če niso razmerja prava, ti pod Save as.., ko izbereš končnico .vtf, ne spusti naprej.
Opkow ::
Kaksen plugin pa rabis?
Pod Save As je med Targa formati omenjen TGA, VDA, ICB, VST. Po defaultu da TGA format, ne ponudi pa nobene moznosti, za izrecno izbiro VST formata.
| » | Izdelava naprave za osvetljevanje TIVOddelek: Elektrotehnika in elektronika | 1720 (1348) | madog |
| » | Katere žarnice za stanovanje?Oddelek: Elektrotehnika in elektronika | 4662 (4090) | Karen |
| » | osvetljevanje TIVOddelek: Elektrotehnika in elektronika | 5683 (5033) | Brane2 |
| » | katero 8800gts 320mb ?Oddelek: Kaj kupiti | 2403 (1623) | chucki |
| ⊘ | eMULE in nje problemiOddelek: Programska oprema | 2065 (1546) | Gandalfar |
