Forum » Igre » SOF 2 problem
SOF 2 problem
andrej1986 ::
z JOKER NATLAČENKE sem inštaliru SOF 2 Single demo.
problem je v tem da v igri ni nasilja.
prosim za pomoč!!!
life ist good!
prosim za pomoč!!!
life ist good!
- spremenilo: andrej1986 ()
Xenon ::
1. On your shortcut, right click -> Properties -> add "+set lock_blood 0" to the Target line.
2. When you start the game, pull down the console by pressing "shift" and "¸" (zraven enke)
3. Type "menu lock"
4. A new option on the bottom menu will be activated (it has a pic of a lock). Click on it. It will prompt for a password, you can just press ok.
5. Turn on all of the gore and set a new password (or keep it blank).
6. Restart and play with gore.
www.igralec.com
| » | težave z domačim omrežjemOddelek: Omrežja in internet | 2934 (2524) | jan01 |
| » | microsoft update (problemi)Oddelek: Operacijski sistemi | 2461 (2281) | TechBeats |
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2618 (2574) | Tea Time |
| » | Izgubil sem ključe od avta!Oddelek: Loža | 7096 (5852) | IgorGrozni |
| » | kako lahko hekerji ti vdrejo v računalnikOddelek: Omrežja in internet | 6582 (5697) | SLOWWWeb.net |
