SOF 2 problem
SOF 2 problem
andrej1986 ::
z JOKER NATLAČENKE sem inštaliru SOF 2 Single demo.
problem je v tem da v igri ni nasilja.
prosim za pomoč!!!:(
life ist good!
Xenon ::
:D pejt na to stran http://www.soffiles.com/file.info?ID=27... al pa tuki maš vse napisan Gore can be enabled, found out on raven board
1. On your shortcut, right click -> Properties -> add "+set lock_blood 0" to the Target line.
2. When you start the game, pull down the console by pressing "shift" and "¸" (zraven enke)
3. Type "menu lock"
4. A new option on the bottom menu will be activated (it has a pic of a lock). Click on it. It will prompt for a password, you can just press ok.
5. Turn on all of the gore and set a new password (or keep it blank).
6. Restart and play with gore.
www.igralec.com
težave z domačim omrežjem
Oddelek: Omrežja in internet
132933 (2523) jan01
microsoft update (problemi)
Oddelek: Operacijski sistemi
112460 (2280) TechBeats
Ne predvaja novega audio CD
52616 (2572) Tea Time
Izgubil sem ključe od avta!
367093 (5849) IgorGrozni
kako lahko hekerji ti vdrejo v računalnik
286579 (5694) SLOWWWeb.net
