Forum » Programska oprema » eni čudni mejli, a se komu sanja ...
globoko grlo ::
en je xyz.zl9 velikost 82 kb ta drug je pa zyx.htm velikost 4.5 kb
a kdo ve kaj bi to bilo
StratOS ::
ZL9 extension, je ZoneAlarm Mailsafe Renamed File.
To je vsaka "zagonska" (windows explorer shell) ali kaj podobnega (mail certifikat npr ...) pripeta v attachementu.
Lahko vsebuje poznane ( seveda če je ) sircam virus,W32.Gibe@mm virus ali W32.Magistr.24876@mm ki ga pošlje hostu, lahko pa Zone Alarm, če ga maš in uporabljaš SMTP sam spremeni zagonske datoteke ( pač tiste ki jih imaš definirane ) v zl*, da se ne izvajajo oz oseba ki ti ga je poslala je ZoneAlarm spremenil zagonski tip datoteke v *.zl? zaradi ne prevečnega širjenja različnih virusov, black code ...
Če hočeš kaj več izvedeti poglej Ta link.
končnice ki jih spremeni ZoneAlorm ( Fire Wall program ) so :
ZL0= AAICWpro/ZoneAlarm Mailsafe renamed File =.ade
ZL1= AAICWpro/ZoneAlarm Mailsafe renamed File =.adp
ZL2= AAICWpro/ZoneAlarm Mailsafe renamed File =.bas
ZL3= AAICWpro/ZoneAlarm Mailsafe renamed File =.bat
ZL4= AAICWpro/ZoneAlarm Mailsafe renamed File =.chm
ZL5= AAICWpro/ZoneAlarm Mailsafe renamed File =.cmd
ZL6= AAICWpro/ZoneAlarm Mailsafe renamed File =.com
ZL7= AAICWpro/ZoneAlarm Mailsafe renamed File =.cpl
ZL8= AAICWpro/ZoneAlarm Mailsafe renamed File =.crt
ZL9= AAICWpro/ZoneAlarm Mailsafe renamed File =.exe
ZLA= AAICWpro/ZoneAlarm Mailsafe renamed File =.hlp
ZLB= AAICWpro/ZoneAlarm Mailsafe renamed File =.hta
ZLC= AAICWpro/ZoneAlarm Mailsafe renamed File =.inf
ZLD= AAICWpro/ZoneAlarm Mailsafe renamed File =.ins
ZLE= AAICWpro/ZoneAlarm Mailsafe renamed File =.isp
ZLF= AAICWpro/ZoneAlarm Mailsafe renamed File =.jse
ZLG= AAICWpro/ZoneAlarm Mailsafe renamed File =.lnk
ZLH= AAICWpro/ZoneAlarm Mailsafe renamed File =.mdb
ZLI= AAICWpro/ZoneAlarm Mailsafe renamed File =.mde
ZLJ= AAICWpro/ZoneAlarm Mailsafe renamed File =.msc
ZLK= AAICWpro/ZoneAlarm Mailsafe renamed File =.msi
ZLL= AAICWpro/ZoneAlarm Mailsafe renamed File =.msp
ZLM= AAICWpro/ZoneAlarm Mailsafe renamed File =.mst
ZLN= AAICWpro/ZoneAlarm Mailsafe renamed File =.pcd
ZLO= AAICWpro/ZoneAlarm Mailsafe renamed File =.pif
ZLP= AAICWpro/ZoneAlarm Mailsafe renamed File =.reg
ZLQ= AAICWpro/ZoneAlarm Mailsafe renamed File =.scr
ZLR= AAICWpro/ZoneAlarm Mailsafe renamed File =.sct
ZLS= AAICWpro/ZoneAlarm Mailsafe renamed File =.shs
Kot sam veš imajo mail odjemalci posebej Outlook, IE in sam sistem veliko lukenj ...
Če maš updatan antivirus poleg FW zraven se ti ni treba preveč ubadati, shraniš na disk, preimenuješ, zaženeš seveda pa ni 100% da je to pure code, kajti lahko je kakšen nov virus, ki jih je dandanes malo morje ( novih ! )
P.S : Previdnost nikoli ni odveč, nikoli pa ne veš kaj "dobrega" boš dobil
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Licenca za Zone Alarm antivirusOddelek: Programska oprema | 1828 (1652) | Death Paladin |
| » | Zasedenost CPE?Oddelek: Pomoč in nasveti | 1739 (1642) | jurre |
| » | Za admine: prijava na slo-tech in ZoneAlarmOddelek: Slo-Tech | 1523 (1363) | Primoz |
| » | ZoneAlarm in ApacheOddelek: Omrežja in internet | 1640 (1545) | govno |
| » | Kateri Firewall naj uporabim !!!Oddelek: Pomoč in nasveti | 1401 (1247) | GaPe |
