Forum » Programiranje » [JAVA] Uvoz knjižnice v Eclipse
N-E-O ::
JFreeChart library moram nekako uvoziti v projekt in to storim po naslednjih korakih (google):
Steps:
1. Start Eclipse 3.0. (If you do not have Eclipse installed, visit www.eclipse.org.)
2. Go to File -> New -> Project....
3. Select Java Project and click on Next. Enter in a project name and click Finish.
4. Select the project in the Package Explorer view. Go to Project -> Properties.
5. Click on Java Build Path? on the left-hand side of the dialog box and on the right-hand side
click on the Libraries? tab.
6. Click on Add External JARs...? and locate jfreechart-1.0.0-pre1.jar and jcommon-1.0.0-common.jar.
Click on OK.
7. Select the project in the Package Explorer view. Go to File -> New -> Package. Give the package
a name and click on Finish.
8. Select the newly-created package in the Package Explorer view. Go to File -> New -> Class. Give the
class a name and click on Finish.
9. You are now ready to start using the JFreeChart library!
Ko importam določene pakete, mi jih ne najde. Preprosto podčrta mi jih rdeče npr:
import org.jfree.chart.ChartFactory;
import org.jfree.chart.ChartUtilities;
org.jfree mi podčrta da ne najde.
Kaj bi lahko bil vzrok temu?
Steps:
Click on OK.
Follow the white rabbit.
N-E-O ::
Sem zrihtal. Namesto .jar sem uvažal kar celotno .zip.
Premalo izkušenj na tem področju pač.
| » | win10 disk cleanup - avtomatskoOddelek: Pomoč in nasveti | 1028 (857) | Ijus |
| » | Šifrirana mapaOddelek: Operacijski sistemi | 2816 (2287) | amigo_no1 |
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3670 (3060) | fr!Xy |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2583 (2179) | Swiwer |
| » | RA2 preko dveh modemov?!Oddelek: Igre | 1769 (1664) | bastadu |
