Forum » Pomoč in nasveti » dvd ali cd
dvd ali cd
ST-777 ::
O DVD+R in DVD-R piše v Wikipediji med drugim tole:
The DVD+R format is divergent from the DVD-R format. Hybrid drives that can handle both, often labeled "DVD±RW", are very popular since there is not a single standard for recordable DVDs.
DVD+R has a more robust error management system than DVD-R, allowing for more accurate burning to media independent of the quality of the media. Additional session linking methods are more accurate with DVD+R versus DVD-R, resulting in fewer damaged or unusable discs due to buffer under-run and multi-session disks with fewer PI/PO errors.
Since the DVD+R format is a competing format to the DVD-R format, which is developed by the DVD Forum, it had not been approved by the DVD Forum, which claimed that the DVD+R format was not an official DVD format until January 25, 2008.
blackbfm ::
V glavnem DVD+R je boljši, ni pa tako podprt kot DVD-R. Čeprav pomoje je danes bolj malo naprav, ki tega ne bi znale brati.
| » | "DVD-R" vs. "XviD"Oddelek: Pomoč in nasveti | 3940 (2831) | norcuron |
| » | Razlika med -R in +ROddelek: Pomoč in nasveti | 1962 (1740) | StratOS |
| » | Microsoft in Intel podprla HD DVD standardOddelek: Novice / Optične enote / mediji | 4637 (4001) | Keravica |
| » | ker format DVD-R ALI DVD+R bo prevladalOddelek: Strojna oprema | 2202 (1874) | mare_ |
| » | dvd filmiOddelek: Zvok in slika | 1760 (1682) | Tr0n |
