NVIDIA GeForce GTX 295
2 3
Tr0n ::
Valvoline ::
To sta 2x gtx260 notr.
Kakšna zverina bo šele 2x gtx280.
Tr0n ::
Brezvezno "vkup stancanje" ce mene vprasas. Za tole nucas reaktor.
mesoreznica ::
Meni se ne zdi brezveze. Počakam kako leto ali leto in pol in bodo ugodne ter enako hitre ali hitrejše kot naslednja generacija dragih in top kartic.
Gigabyte UD3P, E8500 @ 4.5 GHz , HD4870-X2, 4GB ram (Xtreeme Dark),
WD Velociraptor, LC Legion-X
Pa ti spet nic ne pomaga. Spet pridejo bolj zahtevne igre in nisi s cakanjem nic naredu.
Edit: drugac pa so podatki mal cudni. 1792MB, kar je 2x (896MB) = GTX260, 480 processor cores kar je 2x(240) = GTX280.
  • spremenil: Dr_M ()
Ok tole pove veliko :)
As we briefly mentioned, the GPUs strapped on to this beast aren't your stock GTX 260 or GTX 280 parts. These chips are something like a GTX 280 with one memory channel disabled running at GTX 260 clock speeds. I suppose you could also look at them as GTX 260 ICs with all 10 TPCs enabled. Either way, you end up with something that has higher shader performance than a GTX 260 and lower memory bandwidth and fillrate (remember that ROPs are tied to memory channels, so this new part only has 28 rops instead of 32) than a GTX 280. This is a hybrid part.
mesoreznica ::
Kako ne. Lej dobil skoraj novo 9800 GX2 za 270€, ki se meri z 280GTX. In kje dobiš GTX 280 za tak denar?
Rabljeno je drugo. Tut GTX280 bi rabljeno dubu precej bolj ugodno kot novo.
mesoreznica ::
Ja ampak ne v tem cenovnem rangu. Sem iskal, verjemi.
Poleg tega zna bit to grafa, ki bo končno poganjala krajsis tako kot treba.
Ze na geizhalsu se dobi GTX280 za zelo ugodno ceno. Novo seveda.
klik
dzinks63 ::
Na Ebay prav tako.
Valvoline ::
In zakaj bi kakšn idiot prodajal gtx280 ??
Se je treba mal zamislit če greš rabljeno iskat.
50-50 verjetnost da je kaj narobe z grafo
Mal si ucasih poglej male oglase, kaj use folk prodaja. In potem se zamislis, koliko dnarja eni zmecejo stran. Blagor njim, ki imajo...
mesoreznica ::
klik
To je še zmeraj skoraj 100€ več kot nova 9800GX2 če že gledaš v tujini.
cena?
mesoreznica ::
Cena nove EVGA 9800 GX2 z 5 let garancije nove je bila 243,39€ v Avstriji. Skupaj z poštnino k nam je 259,83€.
mislim ceno gtx 295.
mesoreznica ::
Aja to pa ne vem. Definitivno v oblakih. :))
Cena za GTX295 bo $499, toliko kot je za X2 4870.
Tr0n ::
More like 599 EUR.
Odvisno od pozresnosti nasih uvoznikov in prodajalcev.
Tom
DJ MartiNi ::
Na Guru3D se da zaslediti preview te kartice. Omenjena cena je 499USD.
Ryzen 7 7800X3D/MSI B850 Edge Ti Wifi/2x16GB G.Skill Ripjaws S5 6000/RX 7900 XT
Ryzen 7 5700X/ASRock B550 PG Velocita/2x16GB G.Skill Ripjaws V 3600/RX 5700 XT
AMD FX-8350/ASRock 970 Extreme4/2x4GB Kingston HyperX Beast 2400/R9 270X
Tr0n ::
In combo with a fairly high end system I recommend a ~650W PSU at minimum.
Se pravi moj Enermax 500 = dead.
  • spremenilo: Tr0n ()
DJ MartiNi ::
Po moje bi bil tisti Enermax dovolj dober.
Pri GTX295 me je najbolj presenetila poraba. Po TDP podatkih naj bi porabila 3W vec kot X2 4870, v praksi pa 10W v idle in celo 50W load manj. Sicer tole se ni final kartica, ampak upam, da bodo koncno se bolj dodelal.
>:D
RC14 ::
Dobra zadeva tale GeForce GTX 295. Sam cena bi morala biti malo nižja. S čim bo kaj ATI/AMD odgovoril?
:4770K@4.5GHz @ BeQuiet!Dark Rock Pro2; MSI Z87 GD65 Gaming; 16GB RAM:
::GTX 1060 6GB; SSD Samsung 840 EVO 250GB; SEAGATE 3TB+3TB+1TB; LG 27"IPS::
:::: XFX 850W Black Edition; X-Fi Titanium; Fractal Design ARC R2 ::::
BuBBle.D ::
ATi-jev odgovor bo 5870X2, do tedaj pa bojo pač prestol predal nVidii.
|MSI MPG Z690 EDGE|Intel Core I7-13700K|Asus RoG RTX5090 Astral|
|64GB Viper Steel 3600Mhz|2TB+3x1TB Kingston KC3000|ROG Falchion Ace HFX KB|
|ASUS TUF GT502|Gigabyte 1600W|LG OLED 32GS95UE-B 4K/240hz 2K/480hz|
In kaj bodo gor nalimal? 3x rv770? >:D
LordTado ::
sistem lahko zejeb__ samo tako da si igre dol potegneš(kupiš) in jih ne igraš in tudi ne spremljaš
ko se 260 poceni daš v sli in igraš...
In mimogrede kupis se novo plato (glede na to, koliko SLI plat ima folk).
mesoreznica ::
Hahahah točno to. Večina je na Intel chipsetih ki imajo CF support.
Kolk sem spremljal naj bi bilo z X58 konec te dileme.
tilinho20 ::
Kar pa je že.
simnov ::
ko bo tole v trgovini bom prodajal svojo 9800gx2 če bo kdo zainterisiran.
DejaVu ::
a lahko poves v kateri trgovini si narocil? lahko mi poves na PM.
filip007 ::
10 FPS več v Crysis za ostale igre je pa itak vseeno imaš 130 FPS na 4870x2 ali 150 FPS na GTX 280...
Pa še napajalc bo drag za tole...
  • spremenil: filip007 ()
Senitel ::
Huh? TDP za GTX 295 je 289W, za 4870 X2 pa 286W. V praksi pa bo poraba nižja. Kaj sanjaš z nekim vesoljskim napajlnikom?
filip007 ::
No OK sem malo mimo pihnil...pol dela recimo na 650W 85% izkoristek ?
simnov ::
9800gx2 ima nekaj pod 200W ,če se ne motim.Potem bo gtx295 še bolj vroča.
mesoreznica ::
650W bo dovolj.
T-Majo ::
Itak vedno napišejo več kot je v resnici. Ziher je ziher.
Se spovnim iz časov 6600GT, ki naj bi bila tudi za tist čase požrešna. Na 230W napajalniku je delala brez enga restarta.
tilinho20 ::
Jah razvoj je tako usmerjen da gre proti večji zmogljivosti, poraba pa ni tako važna. In tako pač je. To smo podprli.;)
batista bomb ::
Prvi primerki že pri nas klik
mesoreznica ::
Če ni to samo elektronika.si nategovanje spet in se dejansko na zalogi je cena precej ugodna za Nvidio in dejansko ponuja dober price/performance primerjavi z HD4870-X2. :)
Tr0n ::
Lol, 500+ EUR.
Thx, but not thx.
keba ::
Za mene totalno razočaranje tale 259, za 500+eur, bi pričakoval da bo pokosila vso konkurenco za najmanj 30%, je pa nekako primerljiva z 4870x2, nekje le malo boljša, pa še vedno v 55nm procesu. Jst osebno počakam še par mesecev da pridejo vn 40nm kartice iz obeh taborov!
tilinho20 ::
Za ceno sploh ne vem kaj je narobe. Je čist OK. V tujini jo imaš celo za 430eur.
Glede čakanja...kaj pa vem...takrat bo ena middle grafa (kakšna za 300€) bo približno enako dobra kot sedaj GTX 295 oz. 4870x2 (recimo primer je bil 9800gx2 in 4870).
mesoreznica ::
Kar sem jaz teste gledal v bistvu pokosi konkurenco kar fajn.
Tale 295ka pokosi vse ATI resitve po dolgem in pocez, za skoraj enako ceno. So sicer primerki 4870X2 ki so par € cenejsi, ampak ta je ze kar nekaj casa na trgu.
2 3
285gtx ali 295gtx? (strani: 1 2 )
5214394 (13517) BuBBle.D
Grafična kartica
182562 (2139) Meizu
Obširni test Grafičnih kartic
435001 (4345) mesoreznica
Grafična GTX280 nasvet
372802 (1899) tilinho20
Informacije o prihajajočih grafičnih karticah
466015 (4209) gruntfürmich
