Forum » Programska oprema » Startup in win 2000
Startup in win 2000
andHoc ::
Dejte mi povedat kam winsi 2000 zapisujejo kere programe zazenejo ob zagonu.
Neki jih je v start up, kaj pa ve
ina ostalih ???
ina ostalih ???
...vse je relativno...
ToniT ::
Poglej v register:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run; ....\RunOnce; .....\RunOnceEx
ender ::
Vse lokacije, kamor se zapišejo programi:
Menu Start/Programs/Startup
Register: HKCU in HKLM \Software\Microsoft\Windows\CurrentVersion\Run, \RunOnce, \RunServices, \RunOnceEx
WIN.INI [windows] load= in run= (samo Win9x/ME)
msconfig kolikor vem ne dela v Win2k
StratOS ::
Poleg tega se da uštimat še startup pri Enviroment parametrih, Explorer shellu ... in še ostalih
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Enkratni zagon programaOddelek: Programiranje | 1480 (1395) | Mercier |
| » | Kako naj ponovno naložim xp-je? (strani: 1 2 )Oddelek: Operacijski sistemi | 6472 (5707) | pilotgirl84 |
| » | Nastavitve v Win2k.Oddelek: Operacijski sistemi | 1428 (1323) | pirx |
| » | Zagon nekaterih programov ob startu windowsov!Oddelek: Operacijski sistemi | 2236 (2079) | b4d |
| » | Naj mi en pova..Oddelek: Programska oprema | 1991 (1883) | Tr0n |
