Startup in win 2000
Startup in win 2000
andHoc ::
Dejte mi povedat kam winsi 2000 zapisujejo kere programe zazenejo ob zagonu.
Neki jih je v start up, kaj pa ve
ina ostalih ???
...vse je relativno...
McHusch ::
v register,
poglej z msconfig
ToniT ::
Poglej v register:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run; ....\RunOnce; .....\RunOnceEx
ender ::
Vse lokacije, kamor se zapišejo programi:
Menu Start/Programs/Startup
Register: HKCU in HKLM \Software\Microsoft\Windows\CurrentVersion\Run, \RunOnce, \RunServices, \RunOnceEx
WIN.INI [windows] load= in run= (samo Win9x/ME)
msconfig kolikor vem ne dela v Win2k
StratOS ::
Poleg tega se da uštimat še startup pri Enviroment parametrih, Explorer shellu ... in še ostalih
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Enkratni zagon programa
Oddelek: Programiranje
51480 (1395) Mercier
Kako naj ponovno naložim xp-je? (strani: 1 2 )
Oddelek: Operacijski sistemi
686470 (5705) pilotgirl84
Nastavitve v Win2k.
61428 (1323) pirx
Zagon nekaterih programov ob startu windowsov!
62236 (2079) b4d
Naj mi en pova..
Oddelek: Programska oprema
91991 (1883) Tr0n
