C# branje pritisnjene tipke
Neon87 ::
Zdravo, delam nekega keyLoggerja(za vajo), vse mi je jasno, mal sem si pomagal z netom in me zanima kaj točno pomeni tale del kode(sem videl nekje,ko je bilo opisano za pomoč).
[DllImport("User32.dll")]
private static extern short GetAsyncKeyState(Keys vKey);
private static extern short GetAsyncKeyState(Int32 vKey);
foreach(System.Int32 i in Enum.GetValues(typeof(Keys)))
if(GetAsyncKeyState(i) == -32767)
keyBuffer += Enum.GetName(typeof(Keys), i) + " ";
v kejBuffer se "zlaga" vse kar je bilo pritisnjeno.
Prosim za kakšno enostavno razlago.
Hvala,LP
  • spremenil: Neon87 ()
darkolord ::
Hm, tole loopa čez vse tipke in za vsako preveri (s funkcijo GetAsyncKeyState (klik)), če je pritisnjena
Neon87 ::
in ka bi to delalo? mogoč preverjalo če je pritisk, vendar zakaj ravno -32767?
darkolord ::
If the most significant bit is set, the key is down, and if the least significant bit is set, the key was pressed after the previous call to GetAsyncKeyState
-32767 = 0x8000 = 1000000000000000
Keylogger
Oddelek: Programska oprema
354056 (2783) Blisk
Funkcija GetAsyncKeyState
Oddelek: Programiranje
62075 (1778) Looooooka
[C++] Sledenje tipkovnici
71908 (1703) TEDY
[C#] unmanaged->managed code
112567 (2442) Zzzzzzz
DirectX, neki ne gre
61577 (1475) Senitel
