Nevarna strojna oprema.
AngelOfDeath ::
Vidim da bi bilo pametno met temo kamor bi lahko dali linke do nevarne strojne opreme.
Žal je samo v angleščini, ker Slovenija nima zadosti denarja za svojo spletno stran. Uporabljam Evropsko Rapex.
Evo da prispevam prvo:
Brand: CHIEFTEC Type/number of model: CFT-620-A12S.
Description: A power supply adaptor for computers, packed in a transparent plastic bag and cardboard box.
Country of origin: Germany .
Nevarnost:
Electric shock and fire
The product poses a risk of electric shock and fire because of:
- inappropriate connection between earth (PE) and the base (it is only welded),
- minimum insulation distances are not respected,
- sharp edges can cut parts of the insulation.
- the supply wires are only welded.
The product does not comply with the Low Voltage Directive and the relevant European standard EN 60950
Ukrep:
Voluntary withdrawal from the market by the distributor.
edit: Slovnica
AngelOfDeath ::
Brand: EuroCASE
Type/number of model: ATX-350 JSP, P#2007-09, 0718001382, ATX 2,03AAA(P4), E401-9
Description: Power supply for computers, sold without packaging, user's manual or installation instructions. Sticker on the side of the product marked with "EuroCASE®", CE, technical parameters, etc.
Country of origin: Unknown
Nevarnost:
Electric shock
The products pose a risk of electric shock because :
- the construction of the converter does not comply with the requirements on distance between primary and secondary windings for reinforced insulation,
- the condensers in primary circuits do not comply,
- the length of the conductors enables by-passing of double insulation in case of connector release and the possibility of the presence of mains voltage on the exit connector,
- the requirements on reinforced insulation between the output connector and mains plug for double insulation are not met.
The product does not comply with the Low Voltage Directive and the relevant European standards EN 55022 and EN 55024
Ukrep:
Voluntary withdrawal from the market and recall from consumers by the distributor.
edit: Slovnica
AngelOfDeath ::
Brand: Mercury
Type/number of model: Model: MKP- 4400, EAN codes: 027050045325/ KE 11071396, 027050045383/ KE 11071396
Description: Power supply for computers, sold without packaging, user's manual or installation instructions. Sticker on the side of the product is marked: "Mercury", CE, technical parameters, etc.
Country of origin: China
Nevarnost:
Electric shock
- the condensers in the primary circuits do not comply ,
- possible risk of injury by electric power caused by accumulated condenser charge after disconnection of device from the mains,
- the length of conductors enables by-passing of double insulation in case of connector release and a possibility of presence of mains voltage on the exit connectors,
- it is not possible to set up the output parameters,
Ukrep:
edit: Slovnica
AngelOfDeath ::
Category: Electrical appliances
Product: Switching mode power supply
Brand: EuroCASE
Type/number of model: ATX-450 JSP, P#2007-09, 0718014014, ATX 2,03AAA(P4), E401-9
Description: Power supply for computers sold without packaging, user's manual and installation guide.
Nevarnost:
Electric shock
The product poses a risk of electric shock because:
- construction of the converter does not comply with the requirements for distance between primary and secondary windings for reinforced insulation,
- the capacitors in primary circuits do not comply,
- values for clearances and creepage distances are less than the minimum required, - the length of conductors enables by-passing of double insulation in the case of connector release and a possibility of presence of mains voltage on exit connectors,
- material of connector is not resistant against excessive heat,
- the product did not pass the tensile test for basic insulation between cover and mains plugs.
The product does not comply with the Low Voltage Directive and the relevant European standards EN 60950, EN 55022, EN 55024 and EN 61000.
Ukrep:
edit: Slovnica
AngelOfDeath ::
Brand: TRUST
Type/number of model: PSU 370W, item no. 14885, EAN code: 8713439148865
Description: Power supply for computers with marking "Trust".
Nevarnost:
Electric shock
- the construction of the converter does not comply with the requirements for distance between primary and secondary windings for reinforced insulation,
- capacitors in primary circuits do not comply with the requirements,
- the length of conductors enables by-passing of double insulation in case of connector release and a possibility of the presence of mains voltage on the exit connectors,
- the material of the connector is not resistant against excessive heat,
- the product does not pass the tensile test for basic insulation between the cover and mains plugs.
The product does not comply with the Low Voltage Directive and the European Standard EN 60950, EN 55022 and EN 55024.
Ukrep:
Sales ban and withdrawal from the market and recall from consumers ordered by the authorities.
edit: Slovnica
AngelOfDeath ::
Brand: ALLIED
a) Type: AL-8400BTX
b) Type: AL-8360BTX
Description: Power supply for computers with CE and RoHS marks, safety warnings in English, German, Italian and French.
Nevarnost:
Electric shock
- the length of conductors enables by-passing of double insulation in case of connector release and the possibility of the presence of mains voltage on exit connectors,
- the products do not pass the tensile test for double insulation between the cover and mains plugs.
The product does not comply with the Low Voltage Directive and the European Standard EN 60950, EN 61000, EN 55022 and EN 55024.
Ukrep:
Voluntary withdrawal from the market and recall from consumers by the importer.
edit: Slovnica
AngelOfDeath ::
Brand: COLORSit
Type/number of model: Type: 400U-SPT
Description: Power supply for computers. The product is packed in a cardboard box with marking "COLORSit The new generation", CE mark and a reference to the standard EN 60950.
Nevarnost:
Electric shock
The product poses a risk of electric shock because :
- the capacitor's discharge is not sufficient,
- the length of the conductors enables by-passing of double insulation in case of connector release and the possibility of presence of mains voltage on exit connectors.
The product does not comply with the Low Voltage Directive and the relevant European standard EN 60950.
Ukrep:
Tole je mislim da zaenkrat vse od 47 - 37 tedna tega leta...
edit: Slovnica
tlozej ::
Pa še stran zveze potrošnikov slovenije:
http://www.zps.si/sl/varnost/odpoklici-...
Hm... v predogledu mi kaže link do strani, ko pridem ponovno na stran, pa ga ne vidim... upam da ga ostali vidite.
  • spremenil: tlozej ()
AngelOfDeath ::
Vidimo vidimo, zbriši cache v brskalniku pa ga boš tudi ti :)
edit: Slovnica
AngelOfDeath ::
HP/Compaq baterije.
Product: Lithium-ion rechargeable battery packs used with Hewlett-Packard and Compaq notebook computers
Brand: Hewlett-Packard and Compaq
Type/number of model: These lithium-ion rechargeable battery packs are used with various Hewlett-Packard and Compaq notebook computers as listed below:
- HP Pavilion: dv1000, dv8000, and zd8000 series.
- Compaq Presario: v2000.
- HP Compaq: nc6110, nc6120, nc6220, nc6230, nx6110, nx6120, nx4800, and nx9600.
(The Compaq Presario V2400, Compaq nc6140 and nx4820 are included in the worldwide recall programme, but HP has not placed these units on the market in the EEA/EFTA). Affected packs will have coding starting with A0, L0, L1, or GC. (Note that not all packs with this starting code are affected however.) Verification of the complete code by HP is required. Products manufactured during the period from December 2004 through March 2006.
Description: There are four different battery pack designs, each of which is compatible with a subset of the listed notebook computers. The date code is embedded in a code printed on an adhesive label affixed to the inner surface of the battery pack. (The battery pack must be removed from the notebook computer to allow access to this label.) The vast majority of affected battery packs will have been included with the 15 models of notebook computer to which they belonged. These notebook computers were last placed on the market around early 2006, and it is very likely that all packaging will since have been discarded.
Country of origin: Japan
Nevarnost:
Fire and burns
The product poses a risk of fire and burns because certain battery packs (shipped in notebooks PC products manufactured between December 2004 and June 2006) may overheat. 28 incidents reported.
Ukrep:
Voluntary corrective actions taken by the manufacturer.
edit: Slovnica
Tilen ::
/sarkazem
Pa sem že mislil, da bo na prvi strani LC power...
AngelOfDeath ::
Product: Computer - Acer Predator Computer
Brand: Acer
Type/number of model: Acer Predator PC ASG7200 / ASG7700
Acer Aspire Predator "Sniper II", 9W.PJRFW.DB6, 4718235899615
Acer Aspire Predator "Trooper II", 9W.PJKF3.D36, 4718235900557
Acer Aspire Predator "Crusher II", 9W.PC8F8.D465, 4718235899868
Acer Aspire Predator "Eliminator II", 9W.PC4C6.DX6, 4718235899967
Description: Personal Computer (PC).
Nevarnost:
Fire
The product poses a risk of fire because under certain circumstances the computer can overheat, and this in turn may cause a number of components to fail. In individual cases there is also a danger of the PC catching fire.
Ukrep:
Voluntary recall from consumers by the importer.
edit: Slovnica
Ploskim črvom so odsekali glave, spomin je ostal
113595 (2810) korenje3
Madžarska uzakonila cenzuro medijev (strani: 1 2 )
Oddelek: Novice / NWO
5924275 (20124) Mr.B
varnost Tagana 330W vprašljiva
131631 (1321) Kaufmann
Windows 2003 Server (strani: 1 2 )
Oddelek: Operacijski sistemi
576045 (5082) undefined
Kateri operacijski sistem?
261627 (1255) boom-bar
