racunalnik moji deli in navijanje
ninjalee ::
System Info Version: 2.2
Operating System: Microsoft Windows XP SP3
Processors: 2 x Intel 2.67 GHz
Graphics Card: NVIDIA GeForce 8600 GTS
Total Physical Memory: 2 GB
Free Physical Memory: 1.33 GB
Motherboard Manufacturer: Gigabyte Technology Co., Ltd.
Motherboard Model: P31-DS3L
Manufacturer: Intel
Family:
Internal Clock: 2.67 GHz
Internal Clock Maximum: 2.67 GHz
External Clock: 333 MHz
Socket Designation: Socket 775
Type: Central
Upgrade:
Capabilities: MMX, CMov, RDTSC, SSE, SSE2
Version: Model 15, Stepping 11
CPUID: 0x000006fb
Description: Primary Display Driver
Manufacturer: NVIDIA
Name: NVIDIA GeForce 8600 GTS
Total Local Video Memory: 256 MB
Total Local Texture Memory: 256 MB
Total AGP Memory: 375 MB
Display Driver: nv4_disp.dll
Display Driver Version: 6.14.11.7824
Driver WHQL Certified: Yes
Max Texture Width : 8192
Max Texture Height: 8192
Max User Clipping Planes: 8
Max Active Hardware Lights: 8
Max Texture Blending Stages: 8
Textures In Single Pass: 8
Vertex Shader Version: 1.1
Pixel Shader Version: 1.4
Max Vertex Blend Matrices: 0
Max Texture Coordinates: 8
Vendor ID: 0x10de
Device ID: 0x0400
Sub-System ID: 0x34481458
Revision: 0xa1
DISKI
WD 500GB
Maktor 80GB
Sata 120GB
MONITOR
Novita lcd 20incni
INTERNET
T2 LINIJA 40/15 VDSL
ZVOCNA REALTEKOVA
ZVOK NA STOLP ZVEZAN SONNY 2500W
 3d mark
3d mark
ME PA ZANIMA KAKO SE GA DA IZBOLJSATI,IN KAKO SE NAVIJA RACUNALNIK,CE KDO VE NAJ PROSIM OPISE MALO TNX VNAPREJ
  • spremenil: ninjalee ()
dzinks63 ::
Nekaj navitja je vsekakor možno.
Procesor npr na : 8x400=3200
Rame upam da so vsaj DDR2 800Mhz
Tudi grafično se bi dalo z riva tunerjem malo doterat.
ninjalee ::
bi lahko zvedel kako se to dela aja rami so DDR2800Mhz
lahko dam se vec slikc za vse,kje pa da dobim ta riva tuner
kaj pa lahko izboljsam z menjavo nove stvari mislim,ker verjetno ni glih vse 100%
ninjalee ::
TO JE PODROBNEJSI OPIS Z EVERESTOM
Tip procesorja DualCore Intel Core 2 Duo E6750, 2666 MHz (8 x 333)
Ime osnovne plošče Gigabyte GA-P31-DS3L (3 PCI, 3 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
Čipset osnovne plošče Intel Bearlake P31
Tip BIOSa Award Modular (07/30/08)
Grafična kartica NVIDIA GeForce 8600 GTS (256 MB)
3D-pospeševalnik nVIDIA GeForce 8600 GTS
Monitor Plug and Play Monitor [NoDB] (17091)
Zvočna kartica Realtek ALC888/S/T @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
Polje Vrednost
Lastnosti procesorja
Ime procesorja Conroe
CPU stepping G0
Engineering Sample Ne
CPUID CPU ime Intel(R) Core™2 Duo CPU E6750 @ 2.66GHz
CPUID Revizija 000006FBh
Napetost jedra 1.350 V
Hitrost CPU
Takt procesorja 2000.0 MHz (original: [ TRIAL VERSION ] MHz)
množilec CPU 6.0x
CPU FSB 333.3 MHz (original: 333 MHz)
Spominsko vodilo 333.3 MHz
DRAM:FSB Ratio 1:1
Predpomnilnik CPU
L1 Code predpomnilnik 32 KB per core
L1 podatkovni predpomnilnik [ TRIAL VERSION ]
L2 predpomnilnik 4 MB (On-Die, ASC, Full-Speed)
Lastnosti osnovne plošče
ID osnovne plošče 07/30/2008-P31-ICH7-6A79OG0WC-00
Lastnosti čipseta
Memory Timings 5-5-5-15 (CL-RCD-RP-RAS)
Command Rate (CR) [ TRIAL VERSION ]
SPD spominski moduli
DIMM1: Transcend JM667QLJ-1G 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM3: Transcend JM667QLJ-1G [ TRIAL VERSION ]
BIOS lastnosti
Datum Sistemskega BIOSa 07/30/08
Datum Video BIOSa 09/11/07
Award BIOS Tip Award Modular BIOS v6.00PG
Award BIOS sporočilo Intel P31 BIOS for P31-DS3L F10A
DMI BIOS Verzija F10A
Lastnosti GPU
Grafična kartica Gigabyte GeForce 8600 GTS
GPU Codename G84GTS (PCI Express 1.0 x16 10DE / 0400, Rev A1)
GPU takt (Geometric Domain) 675 MHz (original: [ TRIAL VERSION ] MHz)
GPU takt (Shader Domain) 1512 MHz (original: [ TRIAL VERSION ] MHz)
Takt spomina 1008 MHz (original: 1008 MHz)
Polje Vrednost
Lastnosti spominskega modula
Ime modula Transcend JM667QLJ-1G
Serijska številka 0007B080h (2159019776)
Datum izdelave Teden 46 / 2007
Velikost modula 1 GB (2 ranks, 4 banks)
Tip modula Unbuffered DIMM
Tip spomina DDR2 SDRAM
Hitrost spomina DDR2-667 (333 MHz)
Širina modula 64 bit
Napetost modula SSTL 1.8
Način detekcije napak Noben
Hitrost osveževanja Zmanjšano (7.8 us), Self-Refresh
Memory Timings
@ 333 MHz 5-5-5-15 (CL-RCD-RP-RAS) / 20-35-3-5-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 266 MHz 4-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2-2 (RC-RFC-RRD-WR-WTR-RTP)
@ 200 MHz 3-3-3-9 (CL-RCD-RP-RAS) / 12-21-2-3-2-2 (RC-RFC-RRD-WR-WTR-RTP)
Polje Vrednost
North Bridge Properties
North Bridge Intel Bearlake P31
Intel Platform Salt Creek
Supported FSB Speeds FSB800, FSB1066, FSB1333
Podprti tipi spomina DDR2-667 SDRAM, DDR2-800 SDRAM
Maximum Memory Amount 4 GB
Revizija / Stepping 02 / A2
Napetost jedra 1.25 V
In-Order Queue Depth 12
Kontroler spomina
Tip Dual Channel (128 bit)
Active Mode Dual Channel (128 bit)
Memory Timings
CAS Latency (CL) 5T
RAS To CAS Delay (tRCD) 5T
RAS Precharge (tRP) 5T
RAS Active Time (tRAS) 15T
Row Refresh Cycle Time (tRFC) 36T
Command Rate (CR) 2T
RAS To RAS Delay (tRRD) 3T
Write Recovery Time (tWR) 13T
Read To Read Delay (tRTR) Same Rank: 4T, Different Rank: 6T
Read To Write Delay (tRTW) 8T
Write To Read Delay (tWTR) Same Rank: 11T, Different Rank: 5T
Write To Write Delay (tWTW) Same Rank: 4T, Different Rank: 6T
Read To Precharge Delay (tRTP) 5T
Write To Precharge Delay (tWTP) 13T
Refresh Period (tREF) 2600T
DRAM Read ODT 3T
DRAM Write ODT 6T
MCH Read ODT 8T
Performance Level 8
Read Delay Phase Adjust Neutral
DIMM1 Clock Fine Delay 13T
DIMM2 Clock Fine Delay 4T
DIMM3 Clock Fine Delay 12T
DIMM4 Clock Fine Delay 3T
Spominska podnožja
DRAM podnožja #1 1024 MB (DDR2-667 DDR2 SDRAM)
DRAM podnožja #2 1024 MB (DDR2-667 DDR2 SDRAM)
PCI Express kontroler
PCI-E 1.0 x16 port #2 V uporabi @ x16 (Gigabyte GeForce 8600 GTS Video Adapter)
Polje Vrednost
BIOS lastnosti
BIOS Version Intel P31 BIOS for P31-DS3L F10A
Proizvajalec BIOSa
Ime firme Phoenix Technologies Ltd.
Polje Vrednost
Lastnosti senzorja
Tip senzorja ITE IT8718F (ISA 290h)
GPU Sensor Type Driver (NV-DRV)
Ime osnovne plošče Gigabyte G31 / G33 / P31 / P35 / X38 Series
Chassis Intrusion Detected Da
Temperature
Osnovna plošča 32 °C (90 °F)
Procesor 35 °C (95 °F)
CPU #1 / Core #1 42 °C (108 °F)
CPU #1 / Core #2 44 °C (111 °F)
Grafični procesor (GPU) 57 °C (135 °F)
WDC WD5000AAKS-00YGA0 [ TRIAL VERSION ]
Ventilatorji
Procesor 902 RPM
Ventilator #4 2184 RPM
Napetosti
CPU jedro 1.22 V
+3.3 V 3.44 V
+12 V [ TRIAL VERSION ]
+5 V Standby 5.19 V
VBAT Baterija 3.31 V
DIMM 1.86 V
Polje Vrednost
Lastnosti GPU
BIOS Version 60.84.5E.00
GPU Codename G84GTS
PCI-naprave 10DE-0400 / 1458-3448 (Rev A1)
Transistorjev 289 miljon
Tehnologija procesa 80 nm
Velikost rezine 169 mm2
Tip vodila PCI Express 1.0 x16 @ x16
Velikost spomina 256 MB
GPU takt (Geometric Domain) 675 MHz (original: 675 MHz)
GPU takt (Shader Domain) 1512 MHz (original: 1500 MHz)
RAMDAC takt 400 MHz
Pixel Pipelines 8
TMU Per Pipeline 1
Unified Shaders 32 (v4.0)
Strojna podpora DirectX DirectX v10
Pixel Fillrate 5400 MPixel/s
Texel Fillrate [ TRIAL VERSION ]
Lastnosti spominskege vodila
Tip vodila GDDR3
Širin a vodila 128 bit
Realni takt 1008 MHz (DDR) (original: 1008 MHz)
Efektive takt 2016 MHz
Pasovna širina [ TRIAL VERSION ]
Razno
Fan Speed 100%
nVIDIA ForceWare Clocks
Standard 2D Grafični procesor (GPU): 675 MHz, Shader: 1500 MHz, Spomin: 1008 MHz
Proizvajalec grafičnega procesorja
Ime firme NVIDIA Corporation
q 6600 go overclocking
Oddelek: Navijanje
81787 (1649) _geek_
Kakšen računalnik ?
122148 (2035) ThomasSGS
Napajalnik
91174 (1136) Pyr0Beast
ugašanje in restartanje računalnika
236720 (6373) Cold1
Pomnilnik / ram
111658 (1580) libreus
