Forum » Programiranje » Java- hibernate.properties not found
xsenon ::
Pozdravljeni,
v javi pišem aplikacijo kjer za povezovanje na bazo uporabljam hiberate library, uvozil sem vse potrebne .jar datoteke vendar ko želim pognati proram se mi v konzoli izpiše:
Prosim, če mi lahko, nekdo ki je že delal z hibernate knjižnico pomaga pri moji težavi. Sem že poskušal zadevo rešiti s pomočjo googla, vendar zaenkrat neuspešno. Če pa kdo pozna kakšno stran kjer je zadeva lepo razložena tudi dobrodošlo.
Hvala za odgovore.
4.11.2008 9:30:20 org.hibernate.cfg.Environment
INFO: Hibernate 3.1.1
INFO: hibernate.properties not found
INFO: using CGLIB reflection optimizer
INFO: using JDK 1.4 java.sql.Timestamp handling
4.11.2008 9:30:20 org.hibernate.cfg.Configuration configure
INFO: configuring from resource: /hibernate.cfg.xml
4.11.2008 9:30:20 org.hibernate.cfg.Configuration getConfigurationInputStream
INFO: Configuration resource: /hibernate.cfg.xml
4.11.2008 9:30:20 org.hibernate.cfg.Configuration addResource
INFO: Reading mappings from resource: hibernate/Todolist.hbm.xml
4.11.2008 9:30:21 org.hibernate.cfg.HbmBinder bindRootPersistentClassCommonValues
INFO: Mapping class: hibernate.Todolist -> TODOList
4.11.2008 9:30:21 org.hibernate.cfg.Configuration addResource
INFO: Reading mappings from resource: hibernate/PortingRequest.hbm.xml
INFO: Mapping class: hibernate.PortingRequest -> PortingRequest
INFO: Reading mappings from resource: hibernate/BlockList.hbm.xml
INFO: Mapping class: hibernate.BlockList -> BlockList
INFO: Reading mappings from resource: hibernate/PortingAuthorization.hbm.xml
INFO: Mapping class: hibernate.PortingAuthorization -> PortingAuthorization
INFO: Reading mappings from resource: hibernate/RepatriationRequestList.hbm.xml
INFO: Mapping class: hibernate.RepatriationRequestList -> RepatriationRequestList
INFO: Reading mappings from resource: hibernate/RepatriationRequestAtSpecificDateList.hbm.xml
INFO: Mapping class: hibernate.RepatriationRequestAtSpecificDateList -> RepatriationRequestAtSpecificDateList
INFO: Reading mappings from resource: hibernate/PortingInquiry.hbm.xml
INFO: Mapping class: hibernate.PortingInquiry -> PortingInquiry
INFO: Reading mappings from resource: hibernate/RoutingRequestList.hbm.xml
INFO: Mapping class: hibernate.RoutingRequestList -> RoutingRequestList
INFO: Reading mappings from resource: hibernate/PrepaidNumberList.hbm.xml
INFO: Mapping class: hibernate.PrepaidNumberList -> PrepaidNumberList
INFO: Reading mappings from resource: hibernate/PortingResponse.hbm.xml
INFO: Mapping class: hibernate.PortingResponse -> PortingResponse
INFO: Reading mappings from resource: hibernate/FullList.hbm.xml
INFO: Mapping class: hibernate.FullList -> FullList
INFO: Reading mappings from resource: hibernate/Users.hbm.xml
INFO: Mapping class: hibernate.Users -> Users
INFO: Reading mappings from resource: hibernate/RoutingConfirmationList.hbm.xml
INFO: Mapping class: hibernate.RoutingConfirmationList -> RoutingConfirmationList
INFO: Reading mappings from resource: hibernate/Operater.hbm.xml
INFO: Mapping class: hibernate.Operater -> Operater
INFO: Reading mappings from resource: hibernate/ProcessSession.hbm.xml
INFO: Mapping class: hibernate.ProcessSession -> ProcessSession
INFO: Reading mappings from resource: hibernate/TimerOptions.hbm.xml
INFO: Mapping class: hibernate.TimerOptions -> TimerOptions
4.11.2008 9:30:21 org.hibernate.cfg.Configuration doConfigure
INFO: Configured SessionFactory: null
4.11.2008 9:30:21 org.hibernate.cfg.HbmBinder bindCollectionSecondPass
INFO: Mapping collection: hibernate.Users.a1s -> PortingInquiry
INFO: Mapping collection: hibernate.Users.a2s -> PortingAuthorization
INFO: Mapping collection: hibernate.Users.a3s -> PortingRequest
INFO: Mapping collection: hibernate.Users.a4s -> PortingResponse
4.11.2008 9:30:21 org.hibernate.connection.DriverManagerConnectionProvider configure
INFO: Using Hibernate built-in connection pool (not for production use!)
INFO: Hibernate connection pool size: 20
INFO: autocommit mode: false
Hvala za odgovore.
kopernik ::
Saj nimaš nobene napake, kolikor vidim. Sicer pa bi morala zadostovati dokumentacija na hibernate.org, tisti začetni vodič ("Getting started quickly"). Napiši en čisto osnoven primer z uporabo te knjižnice in povej, če kaj zajamra. Inicializacija zgleda ok.
xsenon ::
edino kar mi ni všeč pri inicializaciji je druga vrtica kjer mi javi:
najbolj me mede tale datoteka hibernate.properties ker mi ni jasno katera datoteka je to in pa kje mu jo podam.
Hvala za zgornje napotke.
- spremenil: xsenon ()
Tr0n ::
Hibernate po defaultu pogleda v datoteko hibernate.cfg.xml (default v /classes diru komponente, kjer imas zadevo implementirano), kjer imas definirane nastavitev za bazo (JDBC/JNDI) ter poti do mappingov.
xsenon ::
hm in kaj moram jst v tem primeru da mi javi hibernate.properties not found naredit?
hibernate.cfg.xml datoteko imam:)
ta zadeva drugače teče na serverju jaz pa imam ta source, ki je na serverju in želim iz svojega računalnika dobiti podatke iz baze. Ali sploh lahko to počnem na tak način? SEm popoln začetnik kar se tiče hibernate library, do sedaj sem vse delal na low level.
kopernik ::
Saj imaš precej opisano v tutorialu, ki je res povsem začetniški. hibernate.properties ni obvezen, je samo eden izmed načinov, kako skonfigurirati dostop do baze. Tukaj imaš link do tutoriala.
Jasno, da lahko. Server je tudi "samo" računalnik, ki poganja programe, tako kot tvoj desktop. To nima nobene veze s konkretno knjižnico. Vse, kar potrebuješ je dostop do podatkovne baze iz tvoje lokacije, če želiš delati z istimi podatki kot server. Še bolje je, da si pri sebi postaviš instanco baze (tudi oracle ima določeno verzijo baze -oracle express- zastonj za osebno rabo) in testiraš lokalno.
xsenon ::
full hvala za tele odgovore, sedaj so mi stvari že bolj jasne in dobim sledeč izpis:)
predvsem me skrbi spodnji del kjer so izpisane napake....hmmm
4.11.2008 14:22:00 org.hibernate.cfg.Environment
4.11.2008 14:22:00 org.hibernate.cfg.Configuration configure
4.11.2008 14:22:00 org.hibernate.cfg.Configuration getConfigurationInputStream
4.11.2008 14:22:00 org.hibernate.cfg.Configuration addResource
4.11.2008 14:22:01 org.hibernate.cfg.HbmBinder bindRootPersistentClassCommonValues
4.11.2008 14:22:01 org.hibernate.cfg.Configuration addResource
4.11.2008 14:22:01 org.hibernate.cfg.Configuration doConfigure
4.11.2008 14:22:01 org.hibernate.cfg.HbmBinder bindCollectionSecondPass
4.11.2008 14:22:01 org.hibernate.connection.DriverManagerConnectionProvider configure
SEVERE: JDBC Driver class not found: org.gjt.mm.mysql.Driver
java.lang.ClassNotFoundException: org.gjt.mm.mysql.Driver
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at org.hibernate.util.ReflectHelper.classForName(ReflectHelper.java:108)
at org.hibernate.connection.DriverManagerConnectionProvider.configure(DriverManagerConnectionProvider.java:61)
at org.hibernate.connection.ConnectionProviderFactory.newConnectionProvider(ConnectionProviderFactory.java:124)
at org.hibernate.connection.ConnectionProviderFactory.newConnectionProvider(ConnectionProviderFactory.java:56)
at org.hibernate.cfg.SettingsFactory.createConnectionProvider(SettingsFactory.java:366)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:60)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:1869)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1162)
at util.HibernateUtil.(HibernateUtil.java:23)
at test.main.main(main.java:28)
Initial SessionFactory creation failed.org.hibernate.HibernateException: JDBC Driver class not found: org.gjt.mm.mysql.Driver
Exception in thread "main" java.lang.ExceptionInInitializerError
at util.HibernateUtil.(HibernateUtil.java:27)
Caused by: org.hibernate.HibernateException: JDBC Driver class not found: org.gjt.mm.mysql.Driver
at org.hibernate.connection.DriverManagerConnectionProvider.configure(DriverManagerConnectionProvider.java:66)
... 1 more
Caused by: java.lang.ClassNotFoundException: org.gjt.mm.mysql.Driver
... 8 more
Tr0n ::
V tej hibernate.cfg.xml oz. properties fajlu imas definiran JDBC driver org.gjt.mm.mysql.Driver, ki ga nimas prilozenega ob zagonu aplikacije.
Verjetno ti se manjka kak .jar za MySQL JDBC driver.
Tole deployas/poganjas preko Tomcata ali kako drugace?
Ce bos uporabljal MySQL, ti priporocam, da si iz uradne strani presnames MySQL /J connector, ki je v bistvu MySQL JDBC driver in ga skopiras v lib direktorij tvoje aplikacije. Ce zadevo poganjas preko Tomcata, pa .jar skopiras v TOMCAT_HOME/common/lib.
- spremenilo: Tr0n ()
xsenon ::
Zadevo poganjam preko Tomcata (na serverju kjer teče aplikacija je tomcat).
Jaz imam celoten projekt na svojem računalniku, in ko poženem class kjer sem poklical razred ki mi mora vrnit določene telefonske številke mi javi te napake. Ali moram jaz na svojem računalniku postaviti tomcat-a ali to ni potrebno?
Da malo bolj razložim kako celotna zadeva izgleda:
Na neki lokaciji je baza z uporabniki (server stran) na moji strani pa jaz pošiljam zahteve ali pa zahteve prejemam (se pravi lahko sem server ali client). Za prenos podatkov uporabljam SOAP protokol.
Hvala LP
Hvala LP
xsenon ::
ojla,
Uspešno sem namestil tomcat-a v eclipse mu dodal Axis2 importal celoten projekt, uvozil ve potreben .jar file (projekt ne javlja napak), vendar pa imam drugo težavo in sicer, skompajlam projekt se mi postavi na prvo stran (login - do tukaj deluje pravilno). Ko pa vpišem log in podatk in kliknem gumb prijavi(pošlje request za prijavo) mi localhost vrne "request resource not found!"
A se komu kaj svita kje bi lahko bila težava?
Hvala za pomoč.
Hvala za pomoč.
| » | [Java] JPA - transient v orm.xmlOddelek: Programiranje | 1598 (1518) | dmok |
| » | tomcat in datasourceOddelek: Programiranje | 2679 (2436) | infiniteLoop |
| » | Power options nastavitve na prenosnikuOddelek: Pomoč in nasveti | 1679 (1500) | pokovc |
| » | java in zapis v podatkovno bazoOddelek: Programiranje | 2407 (2275) | jogurtTM |
| » | Kako Nazaj Vklopim Hybernate v 2kOddelek: Operacijski sistemi | 1526 (1393) | igorfeher |
