grubby fatal error: unable to find a suitable template
bigk ::
Na Fedora Core 9 sem zasledil sledeči error:
Napaka se pojavi pri namestitvi (ali update) kernela. Pojavila se je pri avtomatičnem updatu z ukazom yum -y upgrade. Enako se zgodi tudi, če kernel namestim z rpm ukazom. V greub.conf kernel ne vpiše novih vrstic za zagon. Če to storim ročno se sistem ne naloži in se ustavi pri inicializaciji gonilnikov, ker ne najde root-a. Spodaj je del verbose inštalacije z rpm-ja:
D: adding 1 entries to Installtid index.
D: opening db index /var/lib/rpm/Sigmd5 create mode=0x42
D: adding 1 entries to Sigmd5 index.
D: opening db index /var/lib/rpm/Sha1header create mode=0x42
D: adding "4bd647eca284f320c65982b6662e59a87ba6a3a5" to Sha1header index.
D: opening db index /var/lib/rpm/Filemd5s create mode=0x42
D: adding 2157 entries to Filemd5s index.
D: install: %post(kernel-2.6.26.6-79.fc9.i586) asynchronous scriptlet start
D: install: %post(kernel-2.6.26.6-79.fc9.i586) execv(/bin/sh) pid 9671
++ uname -i
++ uname -i
+ '[' i386 == x86_64 -o i386 == i386 ']'
+ '[' -f /etc/sysconfig/kernel ']'
+ /bin/sed -i -e 's/^DEFAULTKERNEL=kernel-smp$/DEFAULTKERNEL=kernel/' /etc/sysconfig/kernel
+ /sbin/new-kernel-pkg --package kernel --mkinitrd --depmod --install 2.6.26.6-79.fc9.i586
D: install: waitpid(9671) rc 9671 status 0 secs 61.688
D: running post-transaction scripts
D: Expected size: 18876201 = lead(96)+sigs(344)+pad(0)+data(18875761)
D: Actual size: 18876201
D: kernel-2.6.26.6-79.fc9: Header V3 DSA signature: OK, key ID 6df2196f
D: (null): %posttrans(kernel-2.6.26.6-79.fc9.i586) synchronous scriptlet start
D: (null): %posttrans(kernel-2.6.26.6-79.fc9.i586) execv(/bin/sh) pid 13149
+ /sbin/new-kernel-pkg --package kernel --rpmposttrans 2.6.26.6-79.fc9.i586
D: (null): waitpid(13149) rc 13149 status 0 secs 0.206
D: closed db index /var/lib/rpm/Pubkeys
D: closed db index /var/lib/rpm/Filemd5s
D: closed db index /var/lib/rpm/Sha1header
D: closed db index /var/lib/rpm/Sigmd5
D: closed db index /var/lib/rpm/Installtid
D: closed db index /var/lib/rpm/Provideversion
D: closed db index /var/lib/rpm/Requireversion
D: closed db index /var/lib/rpm/Dirnames
D: closed db index /var/lib/rpm/Triggername
D: closed db index /var/lib/rpm/Conflictname
D: closed db index /var/lib/rpm/Providename
D: closed db index /var/lib/rpm/Requirename
D: closed db index /var/lib/rpm/Group
D: closed db index /var/lib/rpm/Basenames
D: closed db index /var/lib/rpm/Name
D: closed db index /var/lib/rpm/Packages
D: closed db environment /var/lib/rpm/Packages
D: May free Score board((nil))
Obstoječi kernel se normalno zažene. Je možno, da je do kakšne napake prišlo pri nadgradnji iz fc8 na fc9? Obstoječi kernel je ostal od fc8.
Hvala.
l.p.
//bigk K
Arhiviranje serverja s TAR - incremental in FTP na drugo lokacijo in email report - S
Oddelek: Operacijski sistemi
62006 (1917) Daedalus
linux tezava
131812 (1648) CCfly
Varnost v Linuxu
132024 (1730) d0rK
Linux internet povezava problem
442525 (2140) dr.J
Učim se Linux in rabim pomoč
382219 (1830) Gandalfar
