Nalaganje Viste ?
Nalaganje Viste ?
Mitkoo ::
lp eno uprasanje mam ko hocm instalirat windows mi use lepo boota in pridm notr pol morm pa zbrat na ker disk naj bi instalirou .. pa izberem disk mi napise pa Windows is unable to find a system volume that meets its criteria installation ? kej jasno ?
StratOS ::
"Windows is unable to find a system volume that meets it's criteria installation."
Čisto jasno.
Pri poskusu namestitve operacijskega sistema Windows Vista ne morete izbrati ali formatirati particije na trdem disku
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
WindowsImageBackup
Oddelek: Operacijski sistemi
51432 (1246) CyberPunk
Kako pobrisati datoteki, kjer nisi owner?
91280 (875) subby
Windows XP Black screen
124788 (4528) Twix
zvočniki ne delajo
Oddelek: Zvok in slika
311933 (1570) RazzorX
80GB velika FAT 32 particija
101743 (1599) Lith
