Forum » Pomoč in nasveti » Grafična ati hd4850..mogoče serijska napaka???
Tiger92 ::
Rotaidal ::
Zgleda,da je problem z gonilniki...
http://www.microsoft.com/whdc/device/di...
http://www.ocforums.com/showthread.php?...
Ok, the trick is:
1) open your vista registry editor
2) go to the key : HKLM\System\CurrentControlSet\Control\GraphicsDrivers\
3) highlight it then right click on this key
4) Add DWORD TdrDelay
5) Set value of TdrDelay to the number of seconds you allow your GPU to run with no feedback to the system (ie Timeout watchdog..)
http://forums.amd.com/forum/messageview...
Ok, the trick is:
| » | atikmdag.sys - rabim pomočOddelek: Pomoč in nasveti | 7330 (5813) | The Player |
| » | Sesuvanje računalnika (NVIDIA)Oddelek: Pomoč in nasveti | 1663 (1305) | KTr1sk |
| » | Driver za grafično se preneha odzivat in opomore.Oddelek: Pomoč in nasveti | 948 (867) | lopov |
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3703 (3093) | fr!Xy |
| » | windows XP se mi nočejo zagnati (prilagam sliko ekrana)Oddelek: Pomoč in nasveti | 5416 (4101) | vbohinc |
