SSD za sistemski disk
ST-777 ::
CyberPunk je izjavil:
Eno vprasanje... a kdo ve, kaj za en SMART parameter je Reallocation Event Count na MX100?
CrystalDiskInfo pri meni za SSD ne pokaže Reallocation Event Count ampak Reallocated Sector Count. Kaj pa pomeni, je napisano na http://arstechnica.com/civis/viewtopic....
"Reallocated Sector Count = bad sectors in the past; this might have caused problems in the past but does not have to; drives replace weak sectors as a precaution which may never have caused any problems."
CyberPunk ::
Imam oboje - Reallocation Event Count (C4) je 16, Reallocated Sectors Count (5) je pa 0.
ST-777 ::
@CyberPunk, verjetno misliš vrednost, ki je navedena pri Treshold. Oboje pri meni pokaže le za HDD. Za SSD pa samo Reallocated Sector Count.
CyberPunk ::
Ne, v stolpcu Raw Values. Threshold je na 0. Kot receno, na MX100 128 GB je ta vrednost 16, na 256 in 512 GB pa 0.
Še enkrat, v čem je problem ?
ST-777 ::
iloveboobz je izjavil:
CrystalDiskInfo za moj SSD ne pokaže enega od SMART podatkov, ki pa ga pokaže za MX100.
Again, kje je problem ?
SMART pri ssdjih je bolj kot ne za okras. Media wearout je recimo uporaben, to je pa to.
ST-777 ::
Kako je s SMART-om pri SSD-jih, sem izvedel šele sedaj, ko sem prebral tole: "Communicating With Your SSD ... it is important to remember that SMART attributes vary in both meaning and interpretation by manufacturer. Some attributes are considered trade secrets, and not all drives report the same SMART attributes. A manufacturer, in theory, could report only one SMART value and advertise its drive as SMART-enabled. The SMART standard simply refers to a signaling method between sensors in the drive and the host computer, not a standardization of the attributes themselves." http://www.samsung.com/global/business/...
In other words, SSD lahko ima cel kup slabih "sektorjev" pa to nebo nobena panika, ker je to del dizajna flasha.
GenZNPC ::
Sem malo prejle pregledal praktične teste: http://www.computerbase.de/2014-12/sams...
1-2 sekunde gor dol, če gledam mx512gb vs. 500gb sammy
Kolko se pa to nekomu cenovno splača, nevem....
skibidi
enostavno se ne splača, ker je cenovno zelo blizu 850PRO, ni pa nič kaj pretirano hitrejši od value opcij. 5 let garancije je tut kul, sam ne za 50EUR več.
Ko pride 250GB model >100EUR, potem bo pa stvar zelo smiselna. 5 let garancije je tudi fina stvar in včasih vredna tistih par EUR več.
GenZNPC ::
Razen, če majo spet kak "neznan" bug heheh. Bolj realno bo pomladi na cene pogledat...
skibidi
Glede na zrelost tehnologije in poleg vsega še nov kontroler kaki nepričakovani bugi sploh niso tako out of the question. Time will tell, i guess
SuperVeloce ::
sej ne vem, a je mex predrag, da rabijo sedaj drug controller... ker zgleda slabsi od mex.
edit: 2 core, 4 channel. lol, verjetno iops umetno bremzajo
Problem ?
Zakaj misliš tako ?
GenZNPC ::
Je kje kak test, ko so ga fizično odprl in primerjali z projem?
skibidi
GenZNPC je izjavil:
Bolj bi bla zanimiva kaka chipworks analiza, da vidimo, če je flash isti kot pri PRO al so dejansko naredil posebi TLC.
GenZNPC ::
Ja točno to, da ni to nek nateg pa so sam naštancal dva proja v enga in potweakal chipe.
Osebno sem pričakoval malo bolj "revolucionarne" hitrosti.
skibidi
na sataIII je težko bolj revolucionarno......
SuperVeloce ::
Problem ?
Zakaj misliš tako ?
problem je, da z mex in 3 jedri bi bil verjetno boljsi. 1TB verzija seveda dobi tistega, ker ponuca vse kanale. No saj, ugodni itak zgleda ne bodo, tako da ocitno tudi 2 leti po zadnjem nakupu samsunga le tega ne bom kupoval :).
edit: ob izidu 840evo so v reviewih govorili, da je glavni krivec za visji iops ravno mex controller, pa je bila tam samo visja hitrost napram mdx...
sam če bi bil še boljši, bi pa že bil v 850pro teritorju, kar se tiče hitrosti :)
Ubistvo tole z 2 jedrim sploh ni tako slabo, ker pomeni dost nižjo porabo + cenejše za nardit.
Sam ko bi se ta nižja cena tut prenesla na consumerja
PrimozR ::
Nja...
What I do know is that Samsung started the mass production of TLC V-NAND later, which suggests that the two aren't completely uniform. Moreover, from what I know TLC NAND requires some changes to the peripheral circuitry in order to read three bits from one cell, so while the NAND memory arrays could be alike the die size is still likely at least slightly different. Anyway, we'll find out when Chipworks (or some other silicon analysis company) takes a closer look at the NAND die itself.
Nuff said. Isti tech/dizajn verjetno, a vseeno fizično drug die. Torej ne moreš po želji porabljati jedra X za MLC oz. TLC, je vnaprej določen z izdelavo.
Verjetno... Še vedno so to samo špekulacije, vsaj dokler ne dobimo detajlnega reporta od chipworks.
Nemixxx ::
Je pametno razdeliti ssd na 2 particije ? Ker bi si razdelil 128gb , 40gb bi mel za windows (C) , ostalo pa za kakšno igro in program (E), trdi disk pa tako kot ponavadi (D)
|Intel Core i5 2500k 3.30Ghz-OC-[4.60ghz]|Noctua NH-U9B SE2|
|GA-P67A-UD3-B3|R9 290x 4gb|Kingston Blue HyperX 12GB 1600Mhz|
Lahko, sam nwm zakaj bi to pocel na ssdju...
Nemixxx ::
Ja če imam kakšno igro ali program naložen na ssd-ju , se vse veliko hitreje naloži in me to ne moti :D Ne bi pa rad mešal particije za windows z ostalim stvarem.
Zakaj bi se karkoli mesalo.... Z partricijami se ti samo drobi plac, kar pa ni fino pri tako malo placa...
BorutK-73 ::
Brezveze je razdeliti 128GB ssd na 2 particiji. Imej mapo "igre" na C in maš mir in prostor.
GTX970 ::
Nemixxx je izjavil:
To smo počeli 1996 z fdiskom na 1.7 gb diskih :)).In potem iskali določeno zadevo po vseh 12 particijah.
  • spremenilo: GTX970 ()
PrimozR ::
Ha, 128 GB disk particionirati :) Še cel je komaj dovolj za OS in kak pameten program, ne pa da bi še particioniral.
Nemixxx ::
Samo vprašam :D Hvala
OldSkul ::
To je res nesmiselno ...
Aar2rk ::
Jaz imam 256 v dveh particijah, Win7 (135G) in Win8 (87G). Razlika je pa šla v tržna nebesa. Win8 praktično ne uporabljam, Win7 particija ima pa sicer še veliko prostora, ampak 128 pa prav tako nebi delil, ravno za sistem bo zadosti.
Patricije so smiselne v multiboot sistemih (ker sicer drugače ne gre) in pri trdih diskih, ki nosijo tudi sistem. Na majhnih ssdjih pač ne...
SuperVeloce ::
Če želiš gledati E disk v my computer, si omisli kaj takšnega, da si mountaš "igre" folder linux style. Ni potrebnih nobenih particij.
Jaz se itak ze 10 let praskam po glavi, zakaj se windoze ne znebi teh alfabet oznak. Sama zmeda.
PrimozR ::
Hm... http://geizhals.eu/de/?phist=1122682
Če 850 EVO cenovno nadomesti 840 EVO (z nekaj padca cene), zna življenje postati težko za MX100. Od kje tale dvig cene MX100??
Zadnje case se precej komponent takole drazi.
Hja, tanov EVO je še vedno 50€ dražji, tko da ga čaka še kr dosti pocenitev napram MX100.
Med tem časom bo pa oba šišnal ULTRA II, ki je že zdaj najcenejši in spodobno hiter :)
Pa tut Siliconmotion ssdji kr konkretno brcajo budget segment (transcend ssd370 recimo).
SuperVeloce ::
Najcenejši je? Kje? Mogoče bi tega vzel
http://geizhals.at/eu/sandisk-ultra-ii-...
še cenejši transcend
http://geizhals.at/eu/transcend-ssd370-...
muškin ma celo 1TB (ki je tudi enina kapaciteta)
za 330€
http://geizhals.at/de/mushkin-enhanced-...
PrimozR ::
Hja, poglej kje je začel 840 EVO in kje je zdaj. 850 EVO mislim da bo imel enako pot v kratkem, če ne bo šel še nižje. Ni več tako črno belo da vzameš Cruciala očitno :)
Aja, za ceno Mushkina mirno dodam 15 EUR in vzamem 840 EVO, še vedno bolj zaupam Samsungu :P
EDIT: Al pa Sandiska.
  • spremenil: PrimozR ()
bojsi ::
Če je cena enaka, kaj bi vzeli: 840 EVO ali mx100 (oboje 500GB, običajna uporaba, mac)? Katerega torej ali je vseeno? Ima kateri znantno boljši software za osx?
  • spremenil: bojsi ()
Vrži kocko... V resnici je čisto vseeno, oba imata plus in minuse...
PrimozR je izjavil:
Hja no, sej mushkin ni tolk slab, no...
Sicer se splača dat teh 15€ več za bolši random performance, ampak ta SM2246EN kontroler sploh ni slab. Pa tut ni od neke leve firme, ker siliconmotion dela ssd kontrolerje že precej časa (remember EeePC ? ja, ta je mel tut SM kontroler not).
PrimozR ::
A 840 Evo pa MX100 imata enako garancijo? Sasmung je načeloma amlce bolj šparoven, kar se tiče porabe. MX100 ma pa MLC flash...
ja, oba mata 3 leta....
pač, plusi/minus
MX100:
-boljši sustained write
-wannabe powerloss protection
-MLC flash (cca 3x večji endurance kot EVO -- nepomembno za večino ljudi)
840EVO
-manjša poraba (spet kolk manjša je odvisno kater power save funkcije ti chipset podpira)
-boljši burst write in random performance
-magician (načelno nepotreben, razn če ti je do gimicky funkcij :))
Pogledaš, kaj ti je pomembnejše in tisto zbereš.
kuglvinkl ::
In oba imata FDE?
Jap, kompatabilen z M$-ovim eDrive.
840Evo podpira vec zascit.
in kako je ta encrypted drive drugačen od recimo klasičnega FDEja preko ATA passworda ?
