Forum » Pomoč in nasveti » Težave z CD/DVD writerom
r0Ky23 ::
No torej zamenjal sem pekač ker se mi je stari pokvaril.
Sedaj pa ko hočem kaj spečt mi napiše "Unspecified target error" pa nimam pojma kaj naj. Probal sem že CD-R. DVD+R pa nix ne gre.
Ewo log:
Roky
CPU
1A23-0008-2030-1914-4803-8323
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 20.7.2004 0:41:48
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16.12.2003 18:18:06
Nero version: 6.3.0.3 (Nero Express)
Recorder: < Optiarc DVD RW AD-7191S> Version: 1.01 - HA 1 TA 0 - 6.3.0.3
Adapter driver: < atapi> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: < NW3711X TYR773M >Version: 1.0 - HA 2 TA 0 - 6.3.0.3
Adapter driver: < a7tcy8vd> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y120L0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : Optiarc DVD RW AD-7191S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : NW3711X TYR773M 1.0 a7tcy8vd Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
Optiarc DVD RW AD-7191S F: CDRom3
NW3711X TYR773M G: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523808kB)
Free physical memory: 48MB (50144kB)
Memory in use : 90 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.3.2008
ISO compilation
16:39:17 #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
16:39:17 #2 Text 0 File Reader.cpp, Line 118
Reader running
16:39:17 #3 Text 0 File Writer.cpp, Line 124
Writer Optiarc DVD RW AD-7191S running
16:39:17 #4 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
16:39:17 #5 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
16:39:18 #6 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 959887 (213:18.37, 1874MB)
16:39:18 #7 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
16:39:18 #8 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: Optiarc DVD RW AD-7191S, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
16:39:18 #9 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities:
16:39:18 #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 959888 (959888) = #959888/213:18.38
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 959888 blocks [Optiarc DVD RW AD-7191S ]
16:39:19 #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [Optiarc DVD RW AD-7191S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1965850624, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
959888 | lead-out | 1 | 0x00 | 0x41
16:39:19 #12 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
16:39:19 #13 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
16:39:19 #14 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
16:39:19 #15 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 16.1x (22.218 KB/s)
16:39:19 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
16:39:19 #17 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: < not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 07 4D 43 43 00 00 00 - 00 00 30 30 34 00 38 23 ..MCC.....004.8#
54 37 12 02 54 6C 02 92 - 5F 15 15 0B 0B 08 08 01 T7..Tl.._.......
19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
16:39:19 #18 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 1:38,471 (98471ms) -> OK
16:39:19 #19 Text 0 File DVDPlusRW.cpp, Line 564
Start write address at LBA 0
DVD high compatibility mode: No
16:39:39 #20 SCSI -400 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04710000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
16:39:39 #21 CDR -400 File Writer.cpp, Line 301
Optiarc DVD RW AD-7191S\H1 T0
16:39:39 #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
16:39:39 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
16:39:56 #24 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
16:39:56 #25 Text 0 File dlgbrnst.cpp, Line 1658
16:39:56 #26 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 16.1x (22.218 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 20.7.2004 0:41:48
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 3.8.2004 21:59:44 (Adapter driver for rec)
Kaka ideja?
Ewo log:
Roky
CPU
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry : 1
25.3.2008
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Media Specific:
Sense Code: 0x00
Sense Qual: 0x00
Existing drivers:
Kaka ideja?
- spremenil: r0Ky23 ()
MilkyWay ::
Nero 6.3. je precej stara zadeva in vprašanje, če pravilno podpira nov pekač. Poskusi z novejšo verzijo Nerota.
r0Ky23 ::
Ok zaj z novim nerotom mi gre pečt. Mam pa drugi problem. Audio cd-je normalno zapeče. Mp3 pa čudno, na compu jih ne prepozna, v avtoradiu pa preskakujejo pesmi.
Any idea?
Any idea?
| » | NEC ND-3540A problem...Oddelek: Pomoč in nasveti | 2786 (2077) | dean444 |
| » | LG GSA-4120B dela probleme pri pečenju DL DVD+RjevOddelek: Strojna oprema | 2197 (2006) | mtosev |
| » | Plextor writer 24/48/48 problem! (strani: 1 2 )Oddelek: Strojna oprema | 6235 (5744) | Hux |
| » | Težave s pekačemOddelek: Pomoč in nasveti | 2375 (2315) | boštjan |
| » | PLEXTOR BurfProof unicuje cdje - prosim pomagajte!Oddelek: Pomoč in nasveti | 2164 (1918) | krho |
