Forum » Kaj kupiti » Ali je tale računalnik dober ali bi za takšen denar dobil kaj boljšega?
Pton ::
Pozdravljeni,
kupujem si računalnik ki naj bi izgledal pribljižno takole:
- LC POWER napajalnik METATRON LC8700C 700W/14CM V2.2
CENA: 99€
20/24 pinski priklop
700 W max moči
ATX v2.2
140 mm ventilator
Učinkovitost: >80%
4/8 pinski server/osnovna plošča priklop
3 x 6 pinski PCI express
4 x S-ATA
2 x floppy
- AEROCOOL ohišje ATX AEROCOOL T40
CENA: 63€
ATX
brez napajalnika
dimenzije: 430 x 198 x 552mm
4 x 5.25" (External), 2 x 3.5" (External), 4 x 3.5" (Internal)
ventilator: 120x120x25(mm), 1200 rpm ą 10 %, 23.25dBA, 23.25dBA
- INTEL procesor CORE 2 DUO E8400, 3.00 GHz, LGA775, 6MB, 1333MHZ, BOX
CENA:195€
podnožje: LGA (775-pin)
dejanska delovna frekvenca: 3.00GHz
frekvenca zunanjega vodila: 1333MHz
število jeder: dve
L1 predpomnilnik: 64KB
L2 predpomnilnik: 6MB
podpora 64 bit : da
virtualizacija OS: da
dodatne inštrukcije: MMX, SSE, SSE2, SSE3, SSE4
podpora Hyper-Threading: ne
proizvodni proces: 0.045 µm
napetost jedra: 0.850V-1.3525V
hladilnik priložen: da
- GIGABYTE osnovna plošča GA-P35C-DS3R, DDR2/DD3
CENA: 100€
Procesor
Supports Intel® Core™2 Extreme Quad-Core / Core™2 Duo / Intel® Pentium® Extreme/ Intel® Pentium® D processors
Supports1333/1066/800 MHz FSB
Nabor
Northbridge: Intel® P35 Express Chipset
Southbridge: Intel® ICH9R
Gigabit Lan Controller
8 Channels ALC889A Audio controller
DDR3:
2 x 1.5V DDR3 DIMM sockets supporting up to 4 GB of system memory
Dual channel memory architecture
Support for DDR3 1333/1066/800 MHz memory modules
DDR2:
4 x 1.8V DDR2 DIMM sockets supporting up to 8 GB of system memory(Note 1)
Support for DDR2 1066*/800/667 MHz memory modules
* Please refer "Memory Support List" for memory support information.
Razširitve
1 PCI Express X16 slot
3 PCI Express X1 slots
3 PCI slots
Dimenzije
ATX form factor, 305 x 245mm
Interni I/O priključki
1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x floppy disk drive connector
1 x IDE connector
8 x SATA 3Gb/s connectors
1 x CPU fan header
2 x system fan headers
1 x power fan header
1 x front panel header
1 x front panel audio header
1 x CD In connector
1 x S/PDIF In header
4 x USB 2.0/1.1 headers
1 x power LED header
1 x Chassis Intrusion header
Zunanji I/O priključki
1 x PS/2 keyboard port
1 x PS/2 mouse port
1 x parallel port
1 x coaxial S/PDIF Out connector
1 x optical S/PDIF Out connector
1 x serial port
4 x USB 2.0/1.1 ports
1 x RJ-45 port
6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
BIOS
Supports Virtual DualBIOS
1 x 8 Mbit flash
Use of licensed AWARD BIOS
PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b
- PATRIOT DDR2 RAM, PC2-6400, 800MHZ, S HLADILNIKOM EP, 4GB (2 x 2GB)
CENA: 80€
Kapaciteta: 4GB (2x 2GB)
PC2-6400 800MHz
Latenca: 5-5-5-12
Napetost: 2.0V
Aluminijast hladilnik
100% testiran
- XFX grafična kartica GEFORCE 8800GT XXX EDITION, 512MB DDR3, PCI-E, DVI, TV-Out
CENA: 225€
vmesnik: PCI Express x16
grafični procesor: nVidia Geforce 8800GT (G92)
tovarniško navita GPU/RAM: Da/Da
hitrost grafičnega procesorja: 670MHz (originalno 600MHz)
število stream procesorjev: 112 (Unified)
ROP: 16
količina pomnilnika: 512MB
hitrost pomnilnika: 975MHz DDR (1950MHz) (originalno 900MHz DDR/1800MHz)
podatkovna širina pomnilnika: 256bit
prepustnost pomnilnika: 62.4GB/s
tip pomnilnika: DDR3
podpora SLI: Da
strojna podpora H.264: Da
podprte grafične knjižice: DirectX 10, OpenGL 2.0
shader model: 4.0
RAMDAC: 400 MHz
število ločenih signalov: 2
najvišja ločljivost: 2048x1536
zunanji vtiči: 2x DVI-I (Dual-link), TV izhod
podprtost OS: Windows 98/Me/2000/XP/Vista/Linux
- SEAGATE trdi disk 500GB SATA2, 32MB, 7200RPM (ST3500320AS)
CENA: 105€
Kapaciteta: 500 GB
Vmesnik: S-ATA2
Hitrost vrtenja: 7200 RPM
Predpomnilnik: 32 MB
NCQ tehnologija (native command queuing)
Dostopni čas: 4,16 ms
Dimenzije: 26,1 x 101,6 x 146,99 mm (VxŠxD)
Zanima me če bi bila procesor in plošča zadosti dobra? ali naj vzamem kak ASUS P5N-E, od procesorjev pa kakšnega Q6600? Ali bi morda potreboval še kakšen dodaten hladilnik? Računalnik bom potreboval predvsem za igranje zahtevnih iger.
Že vnaprej hvala za vse odgovore.
CENA: 99€
700 W max moči
ATX v2.2
140 mm ventilator
Učinkovitost: >80%
4 x S-ATA
2 x floppy
CENA: 63€
ATX
brez napajalnika
CENA:195€
število jeder: dve
podpora 64 bit : da
CENA: 100€
Procesor
Nabor
DDR3:
DDR2:
Razširitve
3 PCI slots
Dimenzije
1 x IDE connector
1 x CPU fan header
1 x CD In connector
1 x PS/2 mouse port
1 x parallel port
1 x serial port
1 x RJ-45 port
BIOS
1 x 8 Mbit flash
CENA: 80€
PC2-6400 800MHz
Latenca: 5-5-5-12
Napetost: 2.0V
100% testiran
CENA: 225€
ROP: 16
podpora SLI: Da
shader model: 4.0
RAMDAC: 400 MHz
CENA: 105€
Kapaciteta: 500 GB
Vmesnik: S-ATA2
Matek ::
Procesor in plosca sta super, Q6600 ti ne bo nic pomagal, se posebej ne v igrah. Dodatnega hladilnika tudi ne potrebujes, ce ne nameravas dosti navijati.
Se strinjam z Matekom. Ostalo je vse super.
jimyboy ::
Zamenji grafično, saj imajo XFX zanič vente saj se neda nastavlat hitrosti vrtenja. Kupi Gainwardovo ali pa kakšno drugo z Zalmanovim hladilnikom. Druga možnost je, da kupiš od XFX za 183EUR pa sam menjaš ventilator. Glede plate pa samo to, da kej velik z njo naviju neboš.
- spremenil: jimyboy ()
IVo ::
Seagate je prav tako dober kot WD in Samsung, pač probleme lahko imaš z vsakim (heh odvisno od sreče, pomoje).
| » | Dodajanje serial PORT-a na novejši računalnikOddelek: Strojna oprema | 3056 (2582) | crniangeo |
| » | Katero in kje kupiti osnovno ploŠčo z vodilom 1155 in sata3 priključkomOddelek: Pomoč in nasveti | 3884 (3452) | easyrider3 |
| » | Dva računalnika na izbiroOddelek: Kaj kupiti | 1745 (1588) | opeter |
| » | Je ta konfig OK? Hitra pomoč potrebnaOddelek: Kaj kupiti | 2306 (2111) | Area_51 |
| » | CPu+Plata+RamOddelek: Kaj kupiti | 3985 (3414) | Racko |
