Forum » Pomoč in nasveti » Driver za skener v visti?
DATA-N ::
Prosim za pomoč!
Potrebujem driver za Epson perfection 660 za Visto x64.Obrno sem prav vse pa
- spremenil: DATA-N ()
DATA-N ::
Sem tudi tam iskal pa nič!
Kaj si zdaj naj začnem z skenerjem!
Kupljen pa je bil Marec 2007.
m.i.h.a. ::
poizkusi s tem http://www.hamrick.com/vsm.html
pa še ena navodila, kako usposobit driverje, ki so prišli poleg skenerja za delovanje v visti:
Run the self-extracting .exe (uncheck "When Done Unzipping Run: Setup.exe").
Go to the new directory, open the properties dialog for Setup.exe and select XP SP2 compatibility (this isn't necessary for all installation packages, but
it's necessary for this particular package)
Run Setup.exe
Connect a USB cable and turn on the device
Allow Vista to "Locate and install driver software..."
Select "Install Anyway" when it warns of an unsigned driver (this is perfectly safe in this case because it uses the in-box usbscan.sys driver)
So, in general, follow the same steps you would on XP.
If the setup program fails, try enabling the XP SP2 compatibility (through the properties dialog for the Setup.exe file).
- spremenil: m.i.h.a. ()
Heh, to pa je zato, ker kupujete najcenejše, vstopne modele.
Kot ti je m.i.h.a. že napisal, poskusi namestiti Vuescan. Morda pa bo prepoznal tvoj skener. Sicer na tem seznamu ga ni... je pa vseeno vredno preizkusiti.
DATA-N ::
| » | Gonilniki za stari scaner v win7Oddelek: Pomoč in nasveti | 1455 (1145) | Han |
| » | Linux nadomestki Windows programov?Oddelek: Programska oprema | 2653 (1950) | slitkx |
| » | Problem instalacije XP - SATA diskOddelek: Pomoč in nasveti | 2835 (1841) | Duhec |
| » | Scaner Mustek Bearpaw 2400 CU plusOddelek: Programska oprema | 2150 (1638) | monaco |
| » | Win XP SP2 in BlutoothOddelek: Pomoč in nasveti | 2423 (2268) | jast |
