Forum » Pomoč in nasveti » DirectX...
DirectX...
Bato|\| ::
Imam sledeči problem... Ko dam test direct3d v Diagnostic tool mi napiše:
Direct3D 7 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x80004005 (Generic failure)
Direct3D 8 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
Direct3D 9 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
Ko zaženem kakšno novejšo igro npr. cod4, cod2, nfs prostreet itd... mi napiše "directx encountered an unrecoverable error" sem tudi formatiral in je isto... zdj nevem ali je problem v grafični al kje ...
Imam pa grafično Radeon x1600
- spremenilo: Bato|\| ()
StratOS ::
Daj malce veš informacij o kartici, driverjih, directx verzijo, OS-u ...
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Problem z igranjem iger- DirectxOddelek: Pomoč in nasveti | 2060 (1740) | Venta20 |
| » | Cod5 se ne zaženeOddelek: Pomoč in nasveti | 1160 (1098) | huek111 |
| » | Igre ne delajo?!Oddelek: Pomoč in nasveti | 1417 (1239) | Vlady |
| » | GF2 MX ne delaOddelek: Pomoč in nasveti | 1090 (985) | Vesoljc |
| » | 3D Mark 2000 in 2001 = VELIK PROBLEM :)Oddelek: Pomoč in nasveti | 2575 (2435) | BustA |
