LAN driverji
LAN driverji
|sleeper| ::
Rabu bi nujno gonilnike za lan pri prenosniku Solonote 1557, ali pa rip celotnega cd-ja z vsemi programi, ki ga dobiš ob nakupu tega prenosnika.
Lahko mi tudi date link če je možno kje to dol cuknat....
HVALA!
!Die happy & pretty! :)
StratOS ::
PODVOJEN POST
Preglej predvsem neotov post, mogoče ti bo pomagal
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
  • spremenila: StratOS ()
Flash BIOSa
111393 (1321) Macx95
200GB disk zazna mi ga samo 130
185761 (5633) HeXeD
