Forum » Strojna oprema » Prešvoh napajalec?
Prešvoh napajalec?
SpIcA ::
Danes sm kupil novo mašino. Proc amd64 x2 4800+ ki porabi 65W. Plato gigabyte ga-m57sli-s4. Grafa asus radeon x1950pro ki porabi 260W. Mam pa še dva sata diska in dvd rom. Štartam comp vse normalno...ko pa zlowda winse do konca se pa kr resetira. Mam pa napajalec antec neo HE 430W. Kaj mislite je problem u napajalcu?
P4 RULZZZ!
5er--> ::
Predvidevam, da nisi na novo nameščal sistema in imaš na trdem disku še vedno Windowse z gonilnik prejšnje matične.
SpIcA ::
Aha tako je. Ali je s tem kaj narobe? Kaj bi moral tastare driverje odstraniti. Samo kako?
P4 RULZZZ!
- spremenil: SpIcA ()
5er--> ::
Če si zadovoljen s tem, da se PC restarta ob zagonu windowsev, ne.
Na novo namesti windowse oz. jih popravi, da bodo prepoznali nov sistem.
1) Review and complete Pre-Action Procedures described in the Pre-Action Procedures section above.
2) Change motherboards or move hard drive to new system.
3) Boot the system from the WinXP CD. Have your CDKEY ready.
4) Select the “Install” option. (Don't select repair! The first repair option only verifies XP files against the XP CD versions and makes no system setting changes).
5) Setup will find the XP install that is already there and ask if you wish to repair it. Say yes.
6) Setup will run the upgrade code that will re-enumerate the hardware and set itself to boot from the new controller.
7) Install newer drivers as needed.
Edit:nekaj popravkov.
- spremenilo: 5er--> ()
| » | Windows XP repairOddelek: Pomoč in nasveti | 1474 (1316) | kmetek |
| » | vista problemOddelek: Pomoč in nasveti | 3710 (3369) | markk1 |
| » | [ Windows XP ] Access denied!Oddelek: Operacijski sistemi | 2259 (1974) | opeter |
| » | Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikonOddelek: Pomoč in nasveti | 2691 (2647) | riba43 |
| » | Kako inštaliram Win 2000 iz dosa.Oddelek: Pomoč in nasveti | 1953 (1772) | segi |
