Kje dobiti Hybrid Booster ?
abcdefgh ::
Zdravo!
Zasledil sem da lahko mojo plato (procesor) navijam z Hybrid Booster- jem.
Tako piše na njihovi strani in da je to save overclocking!
Nima to veze, zanima me samo kje to dobit, ker nisn tega najdu nikjer.
LINK MATIČNE
Other Features / Miscellaneous
- CPU Frequency Stepless control |
- ASRock U-COP } link na strani ka je to HYBRID BOOSTER!
- Boot Failure Guard (B.F.G) |
Hvala za odgovore in LP !!!;)
jest10 ::
Daj klikni na povezavo, ki jo imaš na strani, pa boš videl kaj je to:\
To ni nobena posebna zadeva za navijanje...
  • spremenilo: jest10 ()
abcdefgh ::
Sej nisn sprašvau ka je to (jao ljudi moji), a misliš da nisn pred tem prebrau ka je to.
Sej to js rabim spreminjanje CPU frekvence, pa voltaže.
Tak da js to rabim, ni mi pa treba tolmačit kaj je bolše pa da to ni nwm kaj.
Pa da je setFSB, pa BIOS bolši.
To rabim, hvala.
5er--> ::
Q: My ASRock motherboard supports Hybrid Booster. Is Hybrid Booster a
utility to install? Where can I get it?
A: Actually, Hybrid Booster is a combination of several features which have already
been provided with the motherboards.
1. CPU Multiplier: Adjusted by setting onboard FID jumpers.
2. CPU Vcore adjustment: Adjusted by setting BIOS setup option.
3. CPU Frequency Stepless control: Adjusted by setting BIOS setup option.
4. AGP/PCI Frequency control: Adjusted by setting BIOS setup option.
5. ASRock U-COP: Hardware feature, no need to be adjusted.
6. Boot Failure Guard: BIOS feature, no need to be adjusted.
http://www.asrock.com/mb/HybridBooster.... for detailed
Please refer to explanations.
Po domače: to je to kar vidiš v BIOS-u.
kateri procesor, in katero grafično naj kupim?? predlagajte. (strani: 1 2 )
Oddelek: Navijanje
915812 (5022) gogi13
Posodobitev biosa
91775 (1644) theoneman
ASRock K7S8X lastniki, pozor!
Oddelek: Navijanje
474117 (2703) mtic
AMD Athlon XP-M na K7S41GX?
262005 (2005) _mOuSe_
ASRock K7S8X R3.0 - osnovna plošča kupiti ali ne?
142479 (2259) jest10
