ATi HD2900XT ali GeForce 8800GTS 640MB ???
2
dukenukem ::
ehhe kok sit bo pa 8800gt:D
Nesta ::
Lol Medena ;)
V SIT se da lazje primerjat.
Drgac pa cist neumesna hehe ;) Al se v SIT Pove al pa v €, vsi vemo kolko je kej.
Drgac pa upejmo da bo 8800 GT 512 MB tudi tam okol 250€ ali 60.000 SIT ;)
Zheegec ::
Nesta: skoraj 100% je že ta cena... Še sporočim pred izidom.
Janez Janša, 29.04.2014
dukenukem ::
hmm, js sem bral da bo 8800gt počasnejša od 8800gts,nekje piše tko, nekje tko :\
Zheegec ::
Saj je bila tudi na slo-tech novica, preberi jo.
Kartica pride konec meseca v precej omejenih količinah.
dzinks63 ::
:)) Seveda bo počasnejša od 8800gts, saj ima tudi slabše specifikacije.
NVIDIA 8800GT based on G92 core Early Specs
For those who are interested in G92 core, the first card will be the NV 8800GT card. This card will come with a core clk of 600MHz and memory will be at 1800MHz. The memory width is at 256 bits. There will be two models, one with 256M and another at 512M. It will replace the 8800GTS-320.
This card supports SLI 2.0 which is able to run in a tri card SLI setup. It has DVI-I, TV out and Display Port (requires additional chipset). and Purevideo 2 support.
This model is to fit the gap in between the 8600GTS and 8800GTS. Thus the performance levels should be around there. It is said that it targets the RV670 and the performance of it should be slightly better than the RV670..
GeForce 8800GT has two available models. The first being a 256MB will be priced around USD 199 while the 512MB will be priced at USD 249.
It is slated to launch on 12 November 2007.
GrimReaper ::
Zgleda da bo to končno pravi naslednik 7600GT (8600GT, GTS sta isti k), do konca mesca bomo že počakal, zlo mi je všeč one slot solucija, pa poraba bo najbrž tut majhna, tako da ne bo treba menjat napajalnika.
Sicer pa na Wikipedii piše 112SP, drugje spet 64SP. Pa sej nima veze, če bo zamenjala 8800GTS 320MB, pa če so moral novi 8800GTS povečat število SP da bi se izognil konkurenci v lastni hiši, more bit kr rang stare 8800GTS.
Zheegec ::
8800GTS serija bo po mojih trenutnih informacijah EOL - torej se ne bodo več prodajale.
8800GT bo direktni konkurent RV670, ki bo hitrejša od 8800gts.
Pa počakajmo teste...
dukenukem ::
se prav da bo kvečjem una z 512 hitrejša od 320ke,sj so že jamral nekje, da padajo fpsji v igrah na unih z 320, zarad nenavadne količine rama ,zdj bo tko kot more bit 256 in 512 :D ne pa neki vsred ;)
Zheegec ::
Načeloma naj bi bila hitrejša od GTS 640MB, kako je zares bomo pa kmalu videli 8-)
Xtra ::
Čas za nakup grafike je v tem trenutku NAPAČEN. In sicer zato, ker je Nvidia ravnokar najavila 8800 GT(tisti post jo lepo prikazuje), ki bo po performansah zelo podobna zdajšnji 8800GTS, model GTS bo dobil pa dodatne senčilnike (16) pri isti hitrosti in se bo še boljše primerjal z GTX.
Da pa odgovorim na prvo vprašanje; 8800GTS 320 zbije HD2900XT k nč (za ta dnar škoda 8800GTS 640 gledazt),k je navita pa sploh.Em redek je primer da je boljša ATI-jeva.Pa še to na 1024x768.Na 1280x1024 je 8800GTS 320 kraljica za ta dnar.
Evo primer, da to ni prazno blebetanje.Na Oblivion: The Elder Scrools IV na max quality(uglavnm max).
http://www23.tomshardware.com/graphics_...
Pameten link, ki bo rešil veliko dilem.:)
M-XXXX ::
Še en dober test- se jasno vidi moča Ati-ja
Je kdo opazil boost novih driverjev?
Xtra ::
S tega linka vidm, da GeForce mn elekrtike porab in specifikacij parih graf.
Fantje, številke so eno, praksa je drugo.
Sicer pa:
1.)GeForce ma večje kakor ATI, če primerjamo HD2900XT in 8800gts 320 ko grafi navijemo z stock hlajenjem.
2.)Moj link iz prejsnega posta vam pokaze realnost, nekaj kar se da prijeti, se posebej Oblivionov test, ki sem ga zanalasc postavu.Če še ne veste je trenutno to najbol zajebn spil, bi lahko temo naredu kdo ma vec FPS-jev, ker jih je zelo malo.
Ti M-XXX pa se vid da znaš googlat, ne pa razbrat dejanske stvari.
Še enkrat HD2900XT vs 8800gts 320 je 8800gts 320 zmagala.Ne mislim se spustit u GeForce vs ATI vojno.Zame je škoda dnarja za ati-jevo.
Je pa odločitev na strani tistega, ki kupuje, jz sm izbrou 8800gts 320.
LP:)
  • spremenil: Xtra ()
Zheegec ::
8800GTS serije skoraj že ni več, večina dobaviteljev že nima več zaloge.
Nadomestila jo bo 8800GT s 116 tekst. Enotami in pa 256-bit memory busom. Bo 256MB GDDR3 in pa (prva v prodaji) 512MB GDDR4.
to je že skoraj official :)
fakmarjana ::
Xtra .. Oprosti ampak se zelo motiš ...GTS sploh pa 320 je občutno slabša od 2900XT. Moj sošolec je primerjal obedve na istem sistemu...Zanimivo da mu je dala GTS320 v XP winsih 9500, XT pa mu je v VISTI dala 12200 točk v 3dmark2006.
Torej...Živiš v zmoti ^^8-O Je pa res da ni razlike med XT z 512 ali pa z 1024 pomnilnika... Vsaj ne pri 1280x1024
Xtra ::
...zdajšnji 8800GTS, model GTS bo dobil pa dodatne senčilnike (16) -> iz mojega prejsnega posta
Mislim da ne bo odstavljena pač pa nadgrajena.
Lahko se tudi motim.
Grem spat, sm zmatran.
Xtra ::
...videl sem teste in si pač mislim kar vidim.saj pravim lahko se tudi motim.Ničesar si nisem jaz izmislil.Le prebral sem preračunal in konc mesca kupm gts, ne hd2900xt, verjetno nisem neumen.In nisem podvrzen ne nvidii ne atiju.
Dj pa res ajde
darius ::
Malo dnarja malo muzike! testi po internetu so za en K****. Dejansko vidiš potencial grafične ko jo sam sprobaš.
- P5KC - E6750 - HD4870 - 4GB ram - Samsung T220 -
ROVER POWER ;)
Zheegec ::
Xtra: nVidia bo izdala boljšo grafično z istim imenom kot slabšo? Zelooo malo verjento, se ti ne zdi?
fakmarjana ::
Na netu je dosti testov,toda niti dva ne pokažeta istih rezultatov. Tak da...:\
steev ::
Alein 3k1: Si za ziher da pride konec tega mesca. Pa tista cena 250€ ja za 256 ali 512 verzijo.
darius ::
Da pa odgovorim na prvo vprašanje; 8800GTS 320 zbije HD2900XT k nč.
Kdo to reče je nič drugo kot nvidia FANBOY. Še malo pa bo 7600GT bojša od HD2900XT , dečki Zavist! ^^:D peace.
p.s. ATI SE VELIKO BOLJE NAVIJA? DA.:O
ROVER POWER ;)
  • spremenil: darius ()
Zheegec ::
8800GT 512MB DDR4 - 27.10.07.
Najbrž 250EUR z DDV, ni pa še 100%.
darius ::
Nimam pojma zakaj delajo miljon kartic srednjega razreda za ĐABE. Rajši bi si vzeli 7 sekund več časa pa bi naredli eno super duper HD3000XTX 8-) ali 9800GTX na kvadrat, da bi lahko meli vsaj 4xAA v crysis.
ROVER POWER ;)
steev ::
In potem pravis da bo ta grafa 8800gt za 250€ zbila 8800gts?
  • spremenil: steev ()
dzinks63 ::
:)) Z to staro 8800gts 320 bi naj bila 8800gt 512 enakovredna, boljša pa mislim da ne. 8800gt 256 pa na bi sedla v sredino do 8600gts. Sedanjo 8800gts 320, bodo ukinili, ostala bo samo pajačana 8800gts 640. Če bodo take prve začetne cene cca 250€, potem lahko kmalu pričakujemo tudi manj (cca220-230€).
M-XXXX ::
:D Če še nisi opazil je test dolg VEČ STRANI in so tudi rezultati! Glede prakse in teorije- sam zaupam OC-LAB2 ker dobim identične rezultate- veliko strani pa ima kar ene teste (sem že take teste našel da sem sam dobil v 3dmarku 06 več točk kot oni v 05>:D )
Xtra ::
Sj prvim, stvar okusa. nism pa noben fanboy :)
Glede une stvari sem samo komentiral da jo zbije..v skupno gledanem.
2
ATI Radeon HD2900PRO , HD2900GT (strani: 1 2 3 )
10018528 (15143) AapocalypseE
8800 gts ali HD 2900 XT?
101880 (1497) darius
Nabava Gamer računalnika
333324 (2340) JeZo
Radeon HD 2x00 na dolgo in široko
305689 (3407) M-XXXX
ATI Radeon HD 2900XT že mogoče kupiti vsloveniji!
332656 (1790) MEDENA
