nvidia geforce FX5500 256DDR - 128 bit na LCD LG FLATRON L1710s
tomazto ::
nvidia geforce FX5500 256DDR - 128 bit na LCD LG FLATRON L1710s rezultat:
SPLOH NE ZAŽENE MONITORJA - piše na monitorju POWER SAVING MODE ???
dejstva:
- grafična nvidia geforce FX5500 256MB - 128 bit - AGP
- LCD LG FLATRON L1710s
- operacijski sistem WINDOWS XP z SP2
- nastavil tudi BIOS nastavitve na začetno raven
- grafična prej: nvidia geforce 4 MX440 - 128MB
Grafična preverjeno deluje v drugem računalniku.
Kaj tej to je ??? :)
tomazto ::
Kaj je možno da moj AGP slot na moji matični plošči ne podpira te grafične kartice *!??
specifike matične plošče:
Mainboard Model
V7-2
Dimension
244 x 205mm
Processor
Supports AMD Socket-A Athlon/ Athlon XP/ Duron processor with 333/266/133 MHz system bus
Core Logic
VIA 8378(KM400) + 8235
ACPI v1.0b, AGP v3.0, 3.3V PCI v2.2 compliant
Video & Graphics
Built-in graphic core and AGP 8X
High Performance 2D/3D graphics engine
Shared 64MB DDR frame buffer
System Memory
Supports 2DIMM DDR SDRAM 333/266/200MHz, up to 2GB
Audio
Compliant with AC'97 v2.3
18 bits stereo full-duplex CODEC and 6 channel
Communications
On-board full duplex 10/100 base-T Ethernet, MAC built-in VIA 8235
Power Management
ACPI 1.0b compliant
BIOS
Award 2Mb Flash BIOS
Supports password Plug & Play, ACPI, DMI, Smart Fans
IDE Connector
Two 40pins IDE low profile headers, support up to 4 IDE devices
Support PIO mode, ATA 133/100/66
USB Connector
USB2.0 compliant, up to 480Mbps
4 ports USB on rear panel, 2 ports USB on headers
IEEE1394
1394a v2.0 compliant, up to 400Mbps
rear: 1 port, header:1 port
Rear I/O
PS2 x2, RS232 x1, Parallel x1, VGA connector x1, USB x4, LAN port x1, IEEE1394 x1, Line in/Line out/Mic. x1
On board slot
AGP x1, PCI x1, CNR x1(shared with PCI slot)
  • spremenil: tomazto ()
Dva računalnika na izbiro
121772 (1615) opeter
Grafika v prenosniku???
214798 (4218) M@73Y
Je ta konfig OK? Hitra pomoč potrebna
82343 (2148) Area_51
Je kriva plosca za memtest errorje/nestabilnost?
Oddelek: Navijanje
82282 (2134) AtaStrumf
Soyo????
52324 (2260) piko
