[VB6] Problem z ADODB.Connection objektom
mov ax 0x7c0 ::
Pozdravljeni!
Imam naslednji problem.
Na bazo dostopam preko ADODB.Connection objekta in SQLOLEDB providerja... Vse lepo in prav! Koda...:
Set Cn = New ADODB.Connection
Cn.ConnectionTimeout = 500
Cn.CommandTimeout = 500
Cn.Open "Provider=SQLOLEDB;Server=xxxxx;Database=xxxxxx;UID=xxx;PWD=xxx;WSID=mtsPriceList.ctsPriceList"
Ko connection odprem pa ima connection (Cn) naslednji connection string:
Provider=SQLOLEDB.1;Use Procedure for Prepare=1;Auto Translate=True;Packet Size=4096;Workstation ID=MB-PCI-PRO-SRVI;Use
Encryption for Data=False;Tag with column collation when possible=False;
je možno izvorni connection string pridobiti nazaj???
Vsak dan nekaj novega :)
C# OleDB create database
Oddelek: Programiranje
71862 (1694) DubleG
SQL INSERT INTO spremenljivka?
71611 (1550) jakec
asp+access problem
Oddelek: Izdelava spletišč
81406 (1337) appz
printanje v VB6.0
71153 (1057) Zzzzzzz
Visual Basic Developer Site & Forum
262426 (2017) webblod
