C# OleDB create database
DubleG ::
Rad bi najprej preveril če baza obstaja in če ne obstaja, bi jo rad ustvaril. Torej:
Naprimer da je connStr="Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=BLA;Data Source=LOCAL-PC;"
OleDbConnection OleCon = new OleDbConnection();
                OleCon.ConnectionString = connStr;
                try
                    OleCon.Open();
                    goto Nadaljuj;
                catch
                finally{
                    //Initial Catalog does not exist
                    //create it
                    string con = "Integrated Security=" + session.CustomActionData["Integrated Security"].ToString() + ";" + "Initial Catalog=;" + "Data Source=" + session.CustomActionData["Data Source"].ToString() + ";";
                    OleDbConnection OleCon2 = new OleDbConnection();
                    OleCon2 = new OleDbConnection(con);//tukaj brejkne
                    string datasource = session.CustomActionData["Data Source"].ToString();
                     string cad2 = session.CustomActionData["SetTargetPath"].ToString();
                    string sql = "CREATE DATABASE "+datasource+  " ON PRIMARY"
                    + "(Name=" + datasource + ", filename = '" + cad2 + "DB Database\\" + datasource + ".mdf', size=3,"
                    + "maxsize=5, filegrowth=10%)log on"
                    + "(name=mydbb_log, filename='" + cad2 + "DB Database\\" + datasource + ".ldf',size=3,"
                    + "maxsize=20,filegrowth=1)";
                    ExecuteSQLStmt(sql, con);
            Nadaljuj:
                OleCon.Close();
Obstaja kakšna rešitev za katero jaz ne vem?
GA-P55M-UD2,i5,12GB RAM,Radeon HD 4850,Crucial SSD 64GB,
WD 320GB,WD 5000GB,RevoDrive X2 100GB
BHawk ::
Prvo finally block v try->catch->finally se bo vedno izvedel.
Kar moraš ti narediti je, da v catch uloviš napako, ter pogledaš zakaj se ne moreš konektati na bazo. Če je razlog, da initial catalog ni pravilen izvedeš sql ukaz za kreiranje nove baze.
DubleG ::
To sem v teoriji tudi sam želel, pa ne vem kako...
tomaz_sres ::
Živijo,
s tem selectom preveri, če baza obstaja:
select db_id('ImeBaze')
Lep pozdrav, Tomaž Sreš, http://www.sres.si
nuclear ::
v finnaly-u zapri bazo.. v tryu odpri in delaj, v catchu expection meči(pač napako), v finnaly pa zaključi.. nekaj v smislu:
            using (SqlConnection povezava = new SqlConnection(Convert.ToString(Session["cs"])))
                try
                    povezava.Open();
                    string querya = "query";
                    SqlCommand cmd = new SqlCommand(querya, povezava);
                    SqlDataReader dr = cmd.ExecuteReader();
                    if (dr.Read())
                        email = dr["Vrednost"].ToString();
                    dr.Close();
                catch (Exception ex)
                    Response.Write(ex.Message);
                finally
                    povezava.Close();
                    povezava.Dispose();
3p ::
nuclear je izjavil:
Če se ne motim, imaš v tej kodi finally čisto odveč. Using po izhodu iz bloka izvede Dispose (dispose pa Close).
DubleG ::
Kako se v objektu
connection = (ADODB._Connection)dataLinks.PromptNew();
določi privzeto izbran Provider?
DubleG ::
že imam,
connection = new ADODB.ConnectionClass();
connection.ConnectionString = connStr;
//set local COM compatible data type
object oConnection = connection;
s tem da je connStr string v katerem je Provider=SQLOLEDB.1
C# težava
Oddelek: Programiranje
234951 (3797) mladec
SQL problem
142146 (1764) win64
razložitev nekaterij elementov v visual studio 05
72605 (2410) darkolord
OleDb in visual studio .net
162680 (2459) Kovalchuk
branje byte[] iz MS access-ove baze
82335 (2245) BHawk
