ASRock P4I65G pomoč
ASRock P4I65G pomoč
aiko ::
Pozdravljeni.
Imam par vprašanj v zvezi s to plato, in sicer:
1. Kako vključiš Wake On LAN na plati, kajti v biosu nisem našel nič (V navodilih: Supports Wake-On-Lan)
2. Kako povečaš velikost sharanega ram-a za grafiko nad 32MB, tolko gre v biosu (V navodilih: Max. shared memory: 96MB)
3. Koliko je normalno, da se greje Northbridge (865G), koliko pa Southbridge (ICH5) (oba pri keni kr pečeta)
Hvala za help.
aiko ::
ne morem verjet, da noben ne ve...
5er--> ::
1.Verjetno je že default omogočen.
2.V navodilih piše tudi to:
Internal Graphics Mode Select
This option will not appear if you install AGP VGA card on this motherboard.
This allows you to select the size of share memory for onboard VGA. If
larger size of share memory is selected, onboard VGA will get better
resolution under DOS. The default value is [Auto]. Configuration options:
[Auto], [Enabled, 1MB], [Enabled, 4MB], [Enabled, 8MB], [Enabled, 16MB]
and [Enabled, 32MB].
Graphics Aperture Size
This option will not appear if there is no AGP VGA card installed on this
motherboard. It refers to a section of the PCI memory address range used
for graphics memory.
Če daš ven AGP grafično bi verjetno lahko nastavil več kot 32MB.
3. ICH5
Intel 82801EB I/O Controller Hub 5 (ICH5) and Intel 82801ER I/O Controller Hub 5 R (ICH5R) Thermal Design Guide
TC-MAX 115 °C
TC-MIN 0 °C
865G
Intel 865G/865GV/865PE/865P Chipset Thermal Design Guide
TC-MAX 99 °C 1
TC-MAX 95 °C 1, 2
TC-MIN 0 °C 1
NOTES:
1. Thermal specifications assume an attached heatsink is present.
2. This specification applies only to the Intel® 82865PE/82865P MCHs (@ 533 MHz FSB) using 333 MHz
DDR when running the Thermal Testing Software for thermal validation. See Section 3.2 for more details.
Ne morem verjet, da nekateri ne uporabljajo google-a.
[" ICH5 max temp" in " 865G max temp"]
Dead_Eye ::
Ne se preveč zanašat na navodila, ker ponavadi so za več modelov plošč enaka, potem ti pa zraven piše samo ta in ta model,...
The one and only
aiko ::
Za temp. chipsetov sm jaz falu, ker mi ni na pamet padlo, da bi pogledu na net.
AGP grafike nimam, pa še vedno imam možnost samo 32MB.
Kaj pa Wake on lan? Najdu nisem nič kako ga vklopiš. Po defaultu pa tudi ni vklopljen.
Počasen prenos podatkov
122112 (1920) MrStein
Disable VGA
Oddelek: Zvok in slika
201500 (1500) d3n!5
4 GB (4x1 GB) pomnilnika v PC-ju
412881 (1914) krneki0001
Prescott, Canterwood in Springdale
Oddelek: Novice / Matične plošče
52781 (2781) keber
Plate s chipsetom 845 (PE)
61621 (1561) Dr_M
