Forum » Pomoč in nasveti » Cd rom ne pece :(
Cd rom ne pece :(
MensSTYLE ::
Temo vnasam pod splosno pomoc, ker ne vem ali je problem programske ali strojne narave.
Skratka preizkusil sem 4 medije razlicnih proizvajalcev in mi nikakor ne uspe speci cdja oz dvdja...
Spodaj prilagam log iz Alcohol120% burner reporta:
########################### System Information ###########################
Windows XP Professional 5.1 Service Pack 2 (Build 2600)
Processor info: Pentium M processor (797MHz)
Memory Available to Windows: 1.046.640 KB
############################ Program Information ###########################
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcohol_.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: Alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2006 Alcohol Soft Development Team
Version: 1.9.6 ( Build 4719 )
Date: 2006/11/20
Hash: e924b6a93abd8b4a1b0b0a709a16dd8e
Loader: c:\windows\explorer.exe
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Company Name: Alcohol Soft Co., Ltd.
Description: Alcohol virtual device control library
Original: alcoholx.dll
Product: Alcohol
Copyright: Copyright (C) 2000-2006
Version: 4.8.0 ( Build 0 )
Date: 2006/11/18
Hash: 83eeec45bf18fbd60c56a2e3a0191057
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Version: 2.5.1 ( Build 2317 )
Date: 2006/11/17
Hash: a0f7ad7f40c6f36e240f295bcc99de20
########################### User Information ###########################
Licensed to: ~~~~~~~~~~~~
Registered User ID: ~~~~~~~~~~~~
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 128
Examine the accuracy of data read from physical device: Yes
Enable Enhanced Weak Sector Scanner during dumping: No
Overburn disc(s): No
Turn off "Auto-Select best write speed" function if possible: No
Fill memory buffer before recording discs: Yes
Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No
Ignore Media Type: No
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language:
############################ Device(s) List ############################
(E:) MATSHITA UJ-832D (atapi, Port 0, Bus 0, Target 0, Lun 0)
(G:) LA4877S GQB770Q (a62j6bnp, Port 4, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
1394BUS.SYS a62j6bnp.SYS ACPI.sys ACPIEC.sys AegisP.sys
afd.sys Apfiltr.sys atapi.sys ATMFD.DLL audstub.sys
BATTC.SYS Beep.SYS BOOTVID.dll Cdfs.SYS cdrom.sys
CLASSPNP.SYS CmBatt.sys compbatt.sys disk.sys DMICall.sys
dmio.sys dmload.sys drmk.sys dump_atapi.sys dump_WMILIB.SYS
Dxapi.sys dxg.sys dxgthk.sys Fips.SYS fltMgr.sys
Fs_Rec.SYS ftdisk.sys gflmouhid.sys hal.dll HDAudBus.sys
HIDCLASS.SYS HIDPARSE.SYS hidusb.sys HSF_CNXT.sys HSF_DPV.sys
HSFHWAZL.sys HTTP.sys i8042prt.sys imapi.sys intelide.sys
intelppm.sys ipnat.sys ipsec.sys isapnp.sys kbdclass.sys
KDCOM.DLL kmixer.sys ks.sys KSecDD.sys mcdbus.sys
mdmxsdk.sys mnmdd.SYS Modem.SYS mouclass.sys mouhid.sys
MountMgr.sys mrxdav.sys mrxsmb.sys Msfs.SYS msgpc.sys
mssmbios.sys Mup.sys NDIS.sys ndistapi.sys ndisuio.sys
ndiswan.sys NDProxy.SYS netbios.sys netbt.sys Npfs.SYS
ntdll.dll Ntfs.sys ntoskrnl.exe Null.SYS nv4_disp.dll
nv4_mini.sys ohci1394.sys OPRGHDLR.SYS PartMgr.sys pci.sys
pciide.sys PCIIDEX.SYS pcmcia.sys portcls.sys psched.sys
ptilink.sys PxHelp20.sys rasacd.sys rasl2tp.sys raspppoe.sys
raspptp.sys raspti.sys rdbss.sys RDPCDD.sys rdpdr.sys
redbook.sys rspndr.sys RtkHDAud.sys s24trans.sys SCSIPORT.SYS
SonyNC.sys SonyPI.sys sptd.sys sr.sys srv.sys
swenum.sys sysaudio.sys tcpip.sys TDI.SYS termdd.sys
tifmsony.sys update.sys USBD.SYS usbehci.sys usbhub.sys
USBPORT.SYS usbuhci.sys vga.sys VIDEOPRT.SYS VolSnap.sys
w29n51.sys wanarp.sys watchdog.sys wdmaud.sys win32k.sys
WMILIB.SYS
################## Detailed Information of Device(s) ##################
(E:) MATSHITA UJ-832D(0:0) detail information.
Vendor Identification: MATSHITA
Product Identification: UJ-832D
Production Revision Level: 1.03
Support recording method: DAO, RAW SAO, RAW SAO+SUB, TAO, DVD DAO
BURN-Free Technology: BURN-Proof
Auto-Select best write speed: Not Supported
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: Yes/No
Audio Play: Yes
Composite Audio and Video Data Stream: Yes
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: No
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: Yes
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
###################### Source Disc/Image Information ######################
Vrsta: Nepoznan
Pot: D:\Downloads\~~~~~~~~~~~~
Ime: ~~~~~~~~~~~~
Velikost: 635.23 MB
Seja: 1
Sled: 1
Seja 01:
Sled 01: Nepoznan, Dolžina: 283198(553.1 MB)(Nepoznan), Naslov: 000000
####################### Dumping/Recording Progress Log #######################
********* Time stamp of this log file: 27.6.2007 17:47:31 *********
17:47:31 Podatki o procesorju: Pentium M processor (797MHz)
17:47:31 Pomnilnik dostopen Windows-om: 1.046.640 KB
17:47:31 Velikost predpomnilnika: 128 MB
17:47:31 Zaganjanje 'EFM Error Bypass Engine'
17:47:31 Branje slike: D:\Downloads~~~~~~~~~~~~
17:47:31 Podatki o izvoru: Seja: 1, Sled: 1, Dolžina: 553.1 MB / 062:55:73
17:47:37 (E:) MATSHITA UJ-832D(0:0): Način zapisovanja/hitrost
17:47:37 Zapisovanje - DAO / SAO - 12X (1800 KB/sek)
17:47:37 (E:) MATSHITA UJ-832D(0:0): 'BURN-Free' aktiviran
17:48:49 (E:) MATSHITA UJ-832D(0:0) - [Write ERROR], LBA: 18928, Length: 16
S:KEY - 03/0C/00 - "Write Error"
17:48:49 (E:) MATSHITA UJ-832D(0:0): Zapisovanje ni uspelo!
17:48:49 Sporočilo o napaki: [03/0C/00] - Write Error
17:48:49 Branje slike preklicano!
17:48:52 Nekaj ni v redu z zapisovanjem!
Preverite beležko in sporočite napake tehnični podpori.
Drugace je to cdrom iz sonyjevega prenosnika. Sem iskal novejsi software tudi zanj samega, pa brez uspeha.
Vsak namig in usmeritev v resitev problema sta dobrodosla in hvala za trud!
Lep pozdrav,
MensSTYLE
Date: 2006/11/20
Product: Alcohol
Date: 2006/11/18
Date: 2006/11/17
Current Language:
WMILIB.SYS
Test Write: Yes
DVD-ROM Read: Yes
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
R-W Supported: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: Yes
Prevent Jumper: No
Eject Command: Yes
Vrsta: Nepoznan
Ime: ~~~~~~~~~~~~
Velikost: 635.23 MB
Seja: 1
Sled: 1
Seja 01:
Lep pozdrav,
MensSTYLE
MensSTYLE ::
Seveda imam driverje in imam pekaca :)
sej ce ga ne bo slo usposobit bom kupil novi cdrom... btw ma kdo kakega za Sony Vaio laptopa?
danielka84 ::
Smo probali z nerotom pa ne deluje, napise calibration error. Nevem če sploh začne zapisovat, na začetku kaksne pol minute zgleda vse OK potem pa error.
Je možno da bi bil na leči prah in kako bi ga odstranil, kajti v navodilih piše, da se leče nebi smelo dotikati.
Fora je v tem, da sem mu jaz prodal prenosnika, pred tem sem si uspešno posnel dokumente na verbatinov DVD in pred tem sem tud uspešno snemal DVD filme, ko pa je doma sprobal pa tole zajebava. Pa tud na verbatima noče posnet.
Mogoče bi poskusil tud windowse na novo naložit, čeprav se mi zdi maloverjetno, da bi bilo to.
5er--> ::
...morda pa dokončno uniči lečo. :P
Verjetno je pekač zrel za zamenjavo.
Vsaj moj prvi 4x4x32 je z istimi simptomi kmalu bil.
| » | Samba hitrostOddelek: Pomoč in nasveti | 3348 (2708) | e-marko |
| » | ugašanje in restartanje računalnikaOddelek: Pomoč in nasveti | 6716 (6369) | Cold1 |
| » | Podatki iz Memory-Dump-a?Oddelek: Pomoč in nasveti | 2590 (2144) | R33D3M33R |
| » | LG GSA-4120B dela probleme pri pečenju DL DVD+RjevOddelek: Strojna oprema | 2195 (2004) | mtosev |
| » | Lag pri filmčkih v špilihOddelek: Igre | 3128 (2990) | Matev |
