Izdelava .htaccess fajla
Puzo ::
Pozdravljeni!
Pri GoDaddy imam izbrano Linux gostovanje (100GB + domena). Je na Linux platformi. Ker v brskalniku ne morem brskati po mapah npr. http://extreme-slo.net/programi, so mi svetovali, da si naj naredim svoj .htaccess file, katerega ne znam. Na Googlu sem našel samo te HTACCESS makerje, pri katerih lahko narediš samo password protekcijo map..
Ima mogoče kdo kaj več idej, kako se naj tega lotim?
Lp in Hvala,
Mario Ropic
ASUS M2N-e | AMD Athlon 64 X2 6000+ Dual-Core
Crucial Ballistix DDR2-1000 | nVidia 8800GTS
jini ::
http://httpd.apache.org/docs/2.2/howto/...
dodati pa moraš: Options +Indexes
  • spremenil: jini ()
Puzo ::
Naredil bi naj tako:
Options Indexes
Order Allow, Deny
Allow from all
Nato uploadam .htaccess file v root folder (v kateri ni nobenega index.html fajla - ali podobno) in stran ne deluje. Javi mi takšno napako:
nternal Server Errornternal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, support@supportwebsite.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/1.3.33 Server at www.extreme-slo.net Port 80
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187284 (7143) ManDriver
[Linux][OpenSuSe] SVN repozitorij na Windows shared folders in pravice za datotečni s
Oddelek: Operacijski sistemi
162235 (2039) 'FireSTORM'
html ali java, izpis IPja
Oddelek: Programiranje
101588 (1504) Trubadur
Apache/2.0.47 direktoriji
121547 (1423) tx-z
.htacces
101736 (1609) darh
