[Flash] Rabil bi pomoč pri pisanju knjižnjic v AS3
mloncaric ::
Zdravo.
Ker je zunaj nov ActionScript 3 sem dobil veliko vprasanj in problemov...
V AS2 sem pisal knjiznice tako, da sem direktno klical dolocene metode knjiznic. Sedaj sem se odlocil, da bom pisal kar se le da fleksibilne knjiznice, da jih bom kasneje lahko preprosteje uporabljal.
To bom dosegel z ustvarjanjem dogodkov, katere bodo ostale knjiznice kasneje poslusale...
Prilagam preprosto kodo(knjiznica za delo z XML datotekami, FLV predvajalnik in koda fla datoteke).
Rad bi dosegel fleksibilnost knjiznic zato, da jih bom kasneje lahko uporabljal na vec moznih nacinov.
Ce ima kdo kaksno idejo, kako bi se lotil te zadeve mi prosim naj pomaga.
Hvala.
XML loader class:
package com.mloncaric.as3.utils
   import flash.events.Event;
   import flash.events.EventDispatcher;
   import flash.net.URLLoader;
   import flash.net.URLRequest;
   public class LoaderXML extends EventDispatcher
      public static var OPEN:String = "onLoadStart";
      public static var COMPLETE:String = "onLoadComplete";
      public var data:XML;
   //CONSTRUCTOR
      public function LoaderXML(targetXML:String = null)
         if(targetXML != null) this.loadXML(targetXML);
   //METHOD, WHICH GETS AN XML FILE
      public function loadXML(targetXML:String):void
         var loader:URLLoader = new URLLoader(new URLRequest(targetXML));
         loader.addEventListener(Event.OPEN, onLoadStart);
         loader.addEventListener(Event.COMPLETE, onLoadComplete);
   //EVENT HANDLERS
      private function onLoadStart(e:Event):void
         e.currentTarget.removeEventListener(e.type, arguments.callee);
         dispatchEvent(new Event(LoaderXML.OPEN));
      private function onLoadComplete(e:Event):void
         this.data = new XML(e.currentTarget.data);
         dispatchEvent(new Event(LoaderXML.COMPLETE));
My simple FLVPlayer class:
package com.mloncaric.as3.players
   import flash.display.Sprite;
   import flash.media.Video;
   import flash.net.NetConnection;
   import flash.net.NetStream;
   import flash.events.MouseEvent;
   import flash.events.NetStatusEvent;
   import flash.events.SecurityErrorEvent;
   import flash.events.AsyncErrorEvent;
   import com.mloncaric.as3.utils.LoaderXML;
   public class FLVPlayer extends EventDispatcher
      private var lx:LoaderXML;
      private var xml:XML;
      private var nc:NetConnection;
      private var ns:NetStream;
      private var v:Video;
      private var holder:Sprite;
      public var autoPlay:Boolean = false;
      private var isPlaying:Boolean = false;
      private var isPaused:Boolean = false;
      public function FLVPlayer()
         this.lx = new LoaderXML(targetXML);
         this.lx.addEventListener(LoaderXML.OPEN, onStart);
         this.lx.addEventListener(LoaderXML.COMPLETE, onComplete);
      public function createPlayer(array:Object):void
         this.holder = array.holder;
         this.autoPlay = array.autoPlay;
         lx.addEventListener(LoaderXML.COMPLETE, init);
      private function onStart(e:Event):void
         this.lx.removeEventListener(e.type, arguments.callee);
      private function onComplete(e:Event):void
         this.xml = new XML(e.currentTarget.data);
      private function init(e:Event):void
         this.nc = new NetConnection();
         this.nc.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
         this.nc.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);
         this.nc.connect(null);
      private function connectStream():void
         this.ns = new NetStream(this.nc);
         this.ns.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
         this.ns.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
         this.ns.client = new CustomClient();
         if(this.autoPlay) this.onPlay();
         this.v = new Video(this.holder.width, this.holder.height);
         this.v.attachNetStream(this.ns);
         this.holder.addChild(this.v);
      public function onPlay(e:MouseEvent = null):void
         this.ns.play(this.xml.video[0].@src.toString());
         this.isPlaying = true;
      public function onPause(e:MouseEvent = null):void
         this.ns.pause();
      public function onPlayPause(e:MouseEvent = null):void
         this.isPaused = !this.isPaused;
         if(!this.isPlaying && !this.autoPlay) this.onPlay();
         else this.ns.togglePause();
         e.currentTarget.gotoAndStop((this.isPaused)?"play":"pause");
      public function onStop(e:MouseEvent = null):void
         this.ns.pause();
         this.ns.seek(0);
      public function onRewind(e:MouseEvent = null):void
         this.ns.seek(0);
      private function netStatusHandler(event:NetStatusEvent):void
         switch (event.info.code)
            case "NetConnection.Connect.Success":
               this.connectStream();
            break;
            case "NetStream.Play.StreamNotFound":
               trace("Error! File not found...");
            break;
      private function securityErrorHandler(e:SecurityErrorEvent):void
      private function asyncErrorHandler(event:AsyncErrorEvent):void
class CustomClient
   public function onMetaData(info:Object):void
      for(var i:String in info) trace(i, info[i]);
   public function onCuePoint(info:Object):void
main file:
import com.mloncaric.as3.players.FLVPlayer;
var fp:FLVPlayer = new FLVPlayer();
fp.loadXML("playlist.xml");
fp.createPlayer({holder:this, autoPlay:false});
playPauseBTN.addEventListener(MouseEvent.CLICK, fp.onPlayPause);
android črta
Oddelek: Programiranje
412969 (2240) g333kk
Vprašanje iz Jave
71448 (1188) illion
Prosim za predloge in pripombe
Oddelek: Izdelava spletišč
322519 (1662) msjr
Flash CS4 password access AS 3.0
81888 (1630) 680x0
[Flash AS3] Povezava z MySQL
82289 (2150) 680x0
