WinXP home....ne delujejo skenerji
sirotka ::
Zdravo!
Imam en velik problem s skenerji v winxp home. Sprobal 3 skenerje in vedno ista napaka: windows ne more naložiti gonilnika, ker je poškodovan ali manjka. Jasno sem probal več verzij gonilnikov...vedno isti problem! Če priklopiš multifunkcijsko napravo, inštalira printer, fax, skener pa ne! Torej, kje bi lahko bil problem? Gre se pa za firmo, tako da prosim za hiter odgovor...meni je zmankalo idej.
Hvala!
sirotka ::
evo še prava razlaga težave:)
Code 39
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Recommended resolution
Reasons for this error include a driver that is not present; a binary file that is corrupted; a file I/O problem, or a driver that references an entry point in another binary file that could not be loaded.
Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Sem že zamenjal driverje in vse...pa tud različne ferme skenerjev sem sprobal...vedno isto sranje:(
  • spremenil: sirotka ()
Tezave pri downloudanju slik - Windows cannot load the device driver for this hardwar
51193 (1091) kalinovjak
Cd in dvd se ne odzivata
51549 (1489) Sharkb1te
Nujno! Pomoc pri zaznavi CD-roma!!!
81968 (1787) pale
winXP CD-R problem
121656 (1523) PIII850
nasvet za XP
244261 (3853) [t502]
