Forum » Strojna oprema » radeon shared memory
LordTado ::
bok
a je kak možnost da se nardi shared memory k grafični,tako kot je to na integriranih?
Carmack ::
Ja jst mam u BIOS-u nastavleno tko da ima grafična na voljo dodatnih 128 MB sistemskega RAM-a....usaj mislem de je to to...če sm prow navodila razumu...
BRIJAM, ŠIŠAM, ZUBE VADIM...
LordTado ::
a se pr igrah kej pozna,ker ponavadi v page file zapisuje če je video rama premalo,pol pa šrota ko hudiš.
Carmack ::
količina rama je pri igrah najvčkrat pomembna pri teksturah visoke ločljivosti,npr. pri Doom 3 če daš detail level na ultra mi mene napiše da to ni priporočljivo,ker je lahko velikost ene povsem nestisnjene teksture preko 500 mega...jst mam pa 256 MB....
The bigger your video memory, the smaller your Aperture Size could be. However with later games requiring more and more texture memory a good number seems to be 128MB Aperture Size for all cards with 64 MB to 256 MB Video RAM.Setting the Aperture Size to HUGE values will not increase performance because this merely sets the maximum amount of physical memory that can be used. It only makes the GART Table bigger because every 4K page has its own entry, no matter if allocated or not.
Page file je pa na disku,zato je tok počasno kr so diski od oka 100x počasnejši od RAM-a...
Carmack ::
AGP Fast Write
http://www.pcstats.com/articleview.cfm?articleid=1590&page=18:
51. Enable AGP Fast Write
"The AGP fast write BIOS setting allows the processor to communicate directly with the graphics processor, ignoring the need to send data through the system's memory. This should be enabled to provide a performance boost. You should ensure that your video card supports fast writes before setting this option, however.
Almost all recent video cards do support AGP fast write. This setting is generally found in the 'advanced chipset features' section of the BIOS."
| » | katere FPO/Batch e6600 ima mlacom?Oddelek: Kaj kupiti | 1902 (1501) | cpu |
| » | ASUS ali Sapphire X1950proOddelek: Kaj kupiti | 1459 (1392) | Shark-357 |
| » | Katera workstation plata in procesor?Oddelek: Kaj kupiti | 1219 (1071) | opeter |
| » | zamrzovanje samo pri gta SAOddelek: Pomoč in nasveti | 1489 (1288) | balocom |
| » | Razočaran na računalnikom! (strani: 1 2 )Oddelek: Pomoč in nasveti | 4700 (3846) | kajzer |
