Windows Time Syncronization
Torej, če grem v Control Panel, kliknem Date and Time, grem na zavihek Internet TIme in zberem server in hočem sihronizirati uro z serverjem noče delat. Piše Windows has never attempted to syncronize with an internet time server ali pa an error has occurred...
V event viewerju pišeta dve napaki, ki se nanašata na W32Time.
Time Provider NtpClient: An error occurred during DNS lookup of the manually configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup again in 15 minutes. The error was: A socket operation was attempted to an unreachable host. (0x80072751)
The time provider NtpClient is configured to acquire time from one or more time sources, however none of the sources are currently accessible. No attempt to contact a source will be made for 14 minutes. NtpClient has no source of accurate time.
Kako bi lahko to rešil, ter glede na zadnji odstavek bi tudi ostali morali imeti težave. ker piše none of the sources are currently accessible.:\
ATI cards are like buses... They're huge, red and have bad drivers.
HunterMan ::
Men je tut to zadnjič zajebaval, sam po lse je samo porihtal:D
Po kolkem času pa? Ugibam, da po par dnevih.
Edit: typo
  • spremenilo: >>><<< ()
Nihče ne ve, kako lahko to popravim? :\
Danes sem dodal server si.pool.ntp.org in ne gre updejtat uro. Ma kdo kako rešitev?
Z arnesovim strežnikom mi je še vedno šlo (na linuxu)
http://www.arnes.si/ntp/sinhronizacija....
marsovcek ::
Meni čisto lepo dela na ntp1.arnes.si
Ta naslov je predolg in ga ne morem addat kot server;(( .
Marsovcek hvala. Zdaj dela :D .
:\ ? Kaj hočeš s tem povedat? Ona dva serverja od microsofta time.windows. com in še on drug mi ne delata.
Kater naslov je bil predolg?
Menda ja nisi tega noter pisal http://www.arnes.si/ntp/sinhronizacija....
Bios in prehitevanje ure
173058 (2877) Gutjerez
Sinhronizacija časa - Windows 2003
Oddelek: Operacijski sistemi
62010 (1855) imagodei
ura v windowsih xp sp2
71685 (1601) pivmik
Ura na winXP
81308 (1191) Shorty
Ura na računalniku
61479 (1389) Mercier
