Iran - odštevanje
Iran - odštevanje
skumpl ::
Strel455 je izjavil:
https://x.com/Maks_NAFO_FELLA/status/19...
Trump is seriously considering attacking Iran and is holding a crucial meeting with his advisers, - Axios
Jaz moram reči, da ne bom vesel, če se ZDA pridružijo.
Tudi sam nisem ravno navdušen, ampak če odletijo mule, Rusija zelo verjetno ostane brez velikega zaveznika z ogromnimi rezervami nafte in zemeljskega plina.
Na žalost malo prepozno, ker so jih naučili izdelovat šahide.
Grimnir3 ::
kriptobog je izjavil:
Baje so pohekal Iron Dome. Po telegram kanalih se delijo posnetki, kako iron dome posilja izstrelke na Tel Aviv :))
Lool blamaža :D
Če je res seveda.
Da ni spet AI generated bullshit.
  • spremenil: Grimnir3 ()
Bolton may not make it
Lindsey Graham got so exited in anticipation of the next Middle East war, he even got out the tissues and lotion out
Lindsey Graham finding out about Iran and Israel
Strel455 ::
Grimnir3 je izjavil:
Itak da je AI bedarija. Kakšen izstrelek vedno zataji, to ni nič novega.
tetriandoch ::
Pa senator Kennedy tudi. Ne Robert, ampak oni debil iz Louisiane.
Strel455 ::
https://x.com/nexta_tv/status/193487707...
Another Day -- Another General Down. Israel Eliminates Iran's New Chief of General Staff -- He Held the Position for Just a Few Days
Ali Shadmani was appointed Chief of General Staff on June 13, replacing Gholamali Rashid, who had been killed earlier. Now Shadmani himself has been eliminated, according to Israeli sources.
Shadmani was a senior member of the IRGC and a key figure in Iran's military hierarchy.
tetriandoch ::
Mogoče bi lahko uporabili kar svetovalce namesto bomb. Imajo tako trde betice, da bi sigurno prebilo do bunkerja. Razen Witkoffa in Tulsi, je vse tako zabito, da jim ni pomoči.
dronyx je izjavil:
JUST IN - Trump: "We now have complete and total control of the skies over Iran."
Who are "We"? :D
Če pa Trump reče, pl je pa sigurno res. Država 1500 km oddaljena v najbliži točki, ampak oni kontrolirajo zračni prostor z letalom, ki rabi 10 ur vzdrževanja za uro letenja. Pa še takrat ga je treba. Da počiš od smeha.
Strel455 ::
tetriandoch je izjavil:
F-35 (maintenance is 4.4 man-hours per flight hour)
Drugič manj laži.
Lahko pokažeš kako sestreljeno izraelsko letalo?
Strel455 ::
dronyx ::
To se pravi da rusi znajo naredit vojaška letala, nekdo jih je pa naučil izdelat dron z motorjem od kosilnice? :D
PovemVfaco ::
iKst_ je izjavil:
PovemVfaco je izjavil:
Ja, je res prfuknjeno, da zj o nekih sekundah fantaziraš, prj si pa sam od sebe poudaru, d je konflikt še aktualn
Še enkrat. Asad je pobil vsaj 10x več civilistov iz čistega miru kot je bilo vseh žrtev v trenutni vojni med Izraelom in Palestino. Tvoje blodnje o antisemitizmu s strani Izraela so samo to, blodnje.
Sj lahko daš primer ene druge države, k več semitov od izraela pobije vsak dan trenutno. Kolk je semitov izrael pobil v zadnjih 70 letih nam šel štet, k se tebi sedanjost zdi irelevantna. Tud ne malo za tako malo državo. izraelski antisemitizem proti palestincem je v vsakm primeru dobr dokumentirano dejstvo:
Poleg tega pa Izrael uporablja žive ščite:
Strel455 ::
The IDF has published additional footage of strikes on Iranian air defense systems.
https://x.com/PolymarketIntel/status/19...
dronyx je izjavil:
Rusi lovce delajo v malih serijah, letalo na mesec in tako, praktično manufakturno.
Šahide se štepa masovno, par 100 na dan. In to je spet čisto svoja znanost.
https://www.forbes.com/sites/davidhambl...
video:
https://x.com/imp_navigator/status/1764...
Fritz je izjavil:
Izgleda, da bos moral kmalu posodobiti slicico. Pa lep dan.
OutOfTheBox ::
A mislite da bodo kitajci ob vsem tem samo gledali? Stavimo na naslednje scenarije (če ZDA uradno stopi v vojno z Iranom):
1. Kitajska se pridruži in pomaga Iranu
2. Kitajska izkoristi priložnost (distrakcija ZDA) in zavzame Tajvan
3. Kitajska čiča in čaka
Še kakšen predlog? Stave odprte.
WW3 here we come.
(če kdo misli da bo tole kar se dela z Iranom šlo v "lišo" skoz, se moti). Vsaka vojna ima faze plot twistov.
Da. Kitajci bodo samo gledali. Kaj pa lahko naredijo? Izrael je premocan tudi za kitajsko. Izrael ima najboljso vojsko na svetu. To je sedaj ze ocitno.
Še bolj kot vojska je pri židih nevarna njihova mentaliteta. Komot se poberejo iz Izraela kamor hočejo dokler jim tam sužnji ne obnovijo mest. Tudi če jih Iran znuka, čez 5 let bojo nazaj. Pa se ti jebi s takimi...
IgorCardanof ::
Zanimiva akcija:
https://x.com/osint613/status/193493709...
SOME DETAILS OF ISRAELS OPENING STIKE ON TEHRAN - OSINT613
Israel's preemptive military operation against Iran appears to have severely crippled Tehran's missile command structure and its capacity to retaliate, following a complex deception campaign led by Israeli intelligence.
According to sources familiar with the operation, Mossad initiated a targeted disinformation effort days before the strike. Using falsified communications through Iranian channels, they triggered what appeared to be an emergency meeting. The ruse successfully drew the entire senior leadership of Iran's Islamic Revolutionary Guard Corps (IRGC) Aerospace Force, including Commander General Amir Ali Hajizadeh, his deputies, and key technical personnel, into a fortified bunker outside Tehran.
Moments before the strike began, that bunker was hit in a precision airstrike, eliminating Iran's top missile command. Israeli officials say the goal was clear; prevent the launch of what was believed to be over 1,000 ballistic missiles aimed at Israeli territory.
There was absolutely no one alive to give the command to strike back.
Immediately afterward, Israel launched a sweeping campaign across Tehran and other strategic areas, hitting missile sites, infrastructure, and air defenses. The operation had been years in preparation. Mossad sleeper cells, embedded in Iran since as early as 2007, had smuggled hundreds of drones and military equipment into the country using commercial trucks. These assets remained dormant until activated in the hours before the operation.
As the assault began, pre-positioned drones were launched to disable Iran's air defense grid and blind its radar systems. Simultaneously, Mossad teams on the ground carried out a wave of targeted assassinations against Revolutionary Guard figures, paralyzing command structures across multiple regions.
It is estimated that over 15 percent of Iran's ballistic missile arsenal was destroyed in the opening wave. Nearly all critical air defense systems in and around Tehran were neutralized in the first hour. At the same time, Israeli strikes targeted top nuclear scientists involved in the regime's advanced enrichment program.
Iran's ability to respond collapsed. What was expected to be a massive retaliation was reduced to just 150 ballistic missiles launched 20 hours after the Israeli operation began, spread across three waves, a fraction of what had been anticipated.
Israeli officials now estimate more than 40 percent of Iran's launch infrastructure has been wiped out. While Tehran has promised further retaliation, the extent of its remaining capabilities remains in doubt.
Netanyahu described the strike as a "Pager operation on steroids," referring to the covert Mossad mission that targeted over 3,500 Hezbollah operatives. This time, the operation went further eliminating top commanders, dismantling strategic defenses, and neutralizing missile capabilities in one of the most sophisticated preemptive military actions in recent history.
Ne odgovarjam na DM.
Strel455 ::
OutOfTheBox je izjavil:
Kitajska je ena anemična pička.
Kar se tiče Tajvana. Kako to misliš? Kr iz nule bodo napadli Tajvan? Še Američani bi spravljali skupaj kopensko vojsko (marince) vsaj nekaj tednov, ne pa ena Kitajska, ki se nikoli ni šla moderne amfibijske vojne.
IgorCardanof ::
Zadnji dan s tu
https://x.com/noclador
Dobro jutro.
Z dodatnimi štirimi tankerji iz New Jerseyja je zdaj v nočni skupini opazovanih vsaj 32 tankerjev.
Velik del jih je odletel v letalsko oporišče Morón v Španiji, drugi pa v Združeno kraljestvo, Nemčijo, Italijo in eden v Estonijo. Nekaj jih je odletelo na območje CENTCOM-a.
V Združenem kraljestvu, Nemčiji in Italiji se nahajajo eskadrilje ameriških zračnih sil v Evropi. Lovci, ki za polete na Bližnji vzhod potrebujejo podporo tankerjev.
Letalsko oporišče Morón v Španiji je kraj, od koder vzletajo tankerji za oskrbo bombnikov B-2, ki so na poti na bombardiranje Bližnjega vzhoda.
ZDA vstopajo v vojno.
Ljudje se morajo začeti pripravljati in prenehati z zavajajočim mirovniškim blablajem iz obdobja Obame in Merklove, da "ni vojaške rešitve".
Trumpu svetuje general Kurilla, ki je Trumpa že prepričal, da mu je dovolil mesec dni bombardirati Hutije z letali B-2.
Včeraj so ameriške letalske sile čez Atlantik poslale približno 32 tankerjev KC-135 in KC-46... to je le 6,6 % vseh tankerjev ameriških letalskih sil.
Vse evropske članice Nata imajo skupaj le 47 tankerjev... kot vedno jih ima Evropa veliko premalo.
Ne, ZDA v Perzijski zaliv ne pošiljajo "dvanajst lovcev F-22 in F-35".
To je smešno nizko število... kot četrtina eskadrilje vsakega od njih.
Ko ZDA vstopijo v vojno, bo v Evropi več kot 150 lovcev (F-15E, F-16C/D, F-35A), ZDA pa so v njihove baze včeraj poslale tankerje.
5 najpomembnejših spoznanj, ki jih je doslej prinesel izraelski napad na Iran:
1) ruska zračna obramba je sranje (tako kot vse ostalo, kar Rusija proizvaja). Če ste porabili državni denar za ruske sisteme zračne obrambe - velika napaka! Velika!
2) F-35 močno prekaša vse druge tipe bojnih letal na svetu (razen F-22) in nezmožnost vseh obstoječih sistemov zračne obrambe, da bi sledili letalom F-35 pomeni, da je njihova uporaba v boju podobna igranju z kodo za neuničljivost.
Če vaše letalstvo nima letal F-35, nikar ne začnite vojne proti državi, ki jih ima.
3) Brezpilotna letala in rakete ne zmagujejo vojn. Iran uporablja natanko tiste stvari, za katere ameriški tech broji vztrajajo, da bi jih morala ameriška vojska kupiti od njih ... Iran pa je iz dneva v dan bolj sramotno masakriran. Brezpilotna letala in rakete lahko podkrepijo, nikoli pa ne nadomestijo zračnih sil.
4) Ustrezna obramba domovine vključuje ofenzivne zračne zmogljivosti. Izrael lahko ohranja nizke žrtve v doma, ker poleg gostega in večplastnega integriranega sistema protiletalske in protiraketne obrambe tudi usmerja zračno moč v Iran in tam uničuje lanserje raket.
Evropa se mora prebuditi in zgraditi podobne ofenzivne zračne zmogljivosti (lovci, bombniki, tankerji, izvidniški sateliti itd.) - in tudi Ukrajina potrebuje ofenzivno zračno moč!
5) Ne sklepajte sporazumov z diktatorji. Iran lahko zdaj sestavlja jedrsko orožje zato, ker je preveč ameriških administracij in skoraj vse evropske vlade sklenilo dogovore lažnivim iranskim vodstvom, da bi Iranu omogočili "miroljubno jedrsko tehnologijo"... ali so bili zahodni politiki neverjetno neumni in so verjeli tem lažem ali pa so bili skorumpirani in strahopetni in jim je bilo vseeno, da so jim Iranci lagali v obraz. To bi morala biti lekcija za ljudi, ki zahtevajo, da se Evropa in Ukrajina dogovorita s Putinom... diktatorji brez sramu lažejo in dogovori z njimi so brez vrednosti. Veliko bolj smiselno je diktatorje sankcionirati ali bombardirati.
Iran izgublja proti državi, ki je za devetino manjša od njega, Rusija pa je v pat položaju proti državi, ki je za četrtino manjša od nje, skoraj tako, kot da se tako desničarji kot levičarji motijo in so zahodne demokracije dejansko precej dobre v vojni, kadar je to potrebno.
Iz Nemčije in s tolikšnim številom tankerjev: vlečejo 480. bojno eskadriljo z lovci F-16CJ SEAD iz Spangdahlema proti Bližnjemu vzhodu.
Tankerji na Bližnji vzhod vlečejo letala F-15E in F-35A iz Lakenheatha, F-16CJ iz Spangdahlema in F-16C/D iz Aviana.
4 letala F-35A, ki jih vidimo tukaj (eno od njih bo ali pa je pravkar prenehalo jemati gorivo iz letala KC-135) nad Italijo.
Vsa imajo na zunanji strani par raket Sidewinder.
📸: Glenn Lockett, via the Aviationist
Kot je bilo napovedano - letala F-35A iz RAF Lakenheath odhajajo na Bližnji vzhod.
Ta izraelski F-16 leti v Iran z modro neaktivno vadbeno raketo AIM-9 CATM na koncu krila. Verjetno zaradi uravnoteženja obremenitve krila...
To pomeni tudi, da Iran nima več lovcev in lahko Izrael deluje nad Teheranom, kot bi bil na vadbenem poligonu.
Ljudje mi še vedno ne verjamejo, ko rečem, da bodo ZDA vstopile v vojno proti Iranu...
Trump: "Mi"
¯\_(ツ)_/¯
Ne bi se strinjal s tem, da so droni neuporabni. Za primere, kjer napadas drzavo 1000km stran in dron rabi 6 ur da prileti, itak. Ce pa mejis na drzavo, pa droni so in bodo orozje prihodnjih desetletij.
Ni mi čisto jasno, zakaj zdaj jenkiji na bližnji vzhod vlačijo toliko perjadi. A mislijo Iran zbombardirati v srednji vek? Saj Iran vojske več nima, če jo pa ima, je pa povsem neoperativna.
Kako nimajo vojske, ce pa se vedno raketirajo Izrael. Iran ne bo nic unicen, ker ce izvzames vojaske in politicne objekte, ne bo neke resne skode (industrija). Vsaj zaenkrat kaze tako.
Strel455 ::
Focus je na iranskih islamskih blaznežih, ne pa na državi Iran. Iran bo po menjavi oblasti prosperiral.
https://x.com/PahlaviReza/status/193503...
The Islamic Republic has come to its end and is collapsing. What has begun is irreversible. The future is bright, and together we will turn the page of history. Now is the time to stand up; the time to reclaim Iran. May I be with you soon.
  • spremenilo: Strel455 ()
tetriandoch ::
A so odporni na jedrske bombe, da take blebečeš. Naj gredo na tla pa da vidimo. Hezbolah jih je že tolikokrat namlatil na tleh, da so že nehali šteti. Oni so močni samo v pobijanju civilistov. Predvsem žensk in otrok.
Strel455 ::
Hezbolah jih ni nikoli "namlatil na tleh". Hezbolah je imel vedno absurno večje izgube od Izraelcev.
tetriandoch ::
Drugič manj laži.
Da je 4,4 ure zgolj za ogrodje letala si prikladno izpustil. Pri tebi in Izraelcih se motor in elektronika očitno sama servisirata.
Strel455 ::
Saj eno letalo ne servisira samo en mehanik. A zastopiš, kaj pomeni man-hour?
iKst_ ::
Seveda ne boš šel šteti, ker te vse razen točno določenega, čeripikanega časovnega obdobja postavi na laž :)
iKst_ ::
WW3 here we come.
Kaj točno pričakuješ od Kitajske?
ZDA so njihov 3. največji trgovinski partner. EU je na drugem mestu. Irana ni med prvih 20. A res misliš, da bodo Kitajci pljuvali v lastno skledo in dodatno krhali odnose z najpomembnejšimi partnerji zaradi enega Irana? Zakaj že?
  • spremenilo: iKst_ ()
To je vojna zvezd v primerjavi s putlerjevim artilerijskim obstreljevanjem iz ww1. Ne rabiš razruti mest do tal da sovražnika ohromiš
Da iz razdalje 1000plus km vzpostaviš zračno prevlado nad glavnim mestom je INSANE
Izgleda majo židje res po 150+ IQ
  • spremenil: endelin ()
Najbrž je to tudi Ruse malo presralo.
NATO lahko isto naredi nad Moskvo kadarkoli, če hoče. Nobena tampon cona v Ukrajini ne bo tega preprečila.
Hezbolah trenutno nima casa. Rekrutirajo nove ljudi, ki se imajo jajca.
Samo kot opazka, porodile so se velike zamere.
Horde X-navijačev in nabijačev bodo pozivale k novemu nasilju.
Utk je izjavil:
Rusija ima jedrsko orožje, ne potrebuje nobene tampon cone.
To je samo beden izgovor za obnavljanje imperija.
Propagandist explains Russia is restoring its empire
P.S.
@1:40 pokaže podpis aneksije ukrajinskih regij septembra 2022. Postreščki imajo maske čez usta, gauleiterji so pa za svojo mizo, kakih 5m od Putina.
Russian annexation of Donetsk, Kherson, Luhansk and Zaporizhzhia oblasts @ Wikipedia
  • spremenilo: Pac-Man ()
Jarno je izjavil:
Ce pade iranski rezim, bo nasilja veliko manj. Izrael in Iran prakticno nimata nobenih medsebojnih problemov. Iran je zacel vojno iz (verskih) 100% ideoloskih razlogov.
Tako, kot sosedje Izraela, je tudi Rusija bevskajoči, garjav cucek.
Trump: Hameneja vsaj za zdaj ne bomo ubili.
Iran je v brezizhodni situaciji.
tomlin ::
endelin je izjavil:
To, kar gledamo, je dobesedno vojna 21. stoletja proti taktiki iz časa prve svetovne vojne. Medtem ko Putler še vedno prisega na masovno artilerijo in uničevanje vsega pred seboj, drugi iz razdalje preko 1000 km z natančnimi udarci onesposobijo ključne točke – brez rušenja mest do tal. Vzpostaviti lokalno zračno prevlado nad glavnim mestom iz takšne razdalje je vrhunski prikaz sodobne vojaške tehnologije in koordinacije.
Izraelci znajo združiti inteligenco, tehnologijo in taktiko – impresivno, ni kaj.
M. Friedman
Jarno je izjavil:
A si res tako nerazgledan ali pa res nimaš pojma o zgodovini konflikta v Zahodni Aziji. 8-)
Fritz, razsvetli me. Imas odlicen track record na tem forumu.
Grimnir3 ::
Fritz je izjavil:
Jarno je izjavil:
Pravi zaposleni v slovenski vojski ki je obenem redni navijač vseh totalitarnih režimov.
Kaj nimate nobenega internega nadzora in kodeksa obnašanja?
tomlin je izjavil:
endelin je izjavil:
S polno ritjo je lahko srati. Prav dolgo pa to ne bo šlo, ker terja precej resursov. Iran ni poražen in niti ni na poti v poraz. Mislim res, govorite kot da apartheidistan ni nič fasal in bo jutri zasedel Iran. Ain't gonna happen.
Grimnir3 ::
Fritz je izjavil:
tomlin je izjavil:
endelin je izjavil:
Lol.
Pridi nazaj v realnost.
Pa saj židekom ni v interesu, da zasedejo cel Iran. V interesu jim je samo zamenjava oblasti, za kar pa ne bo šlo tako veliko resursov. Pa itak jim bo zdaj dobrodušno pomagal stric Donald, kjer je pa resursov ohoho še pa še.
Ideje, da bi si žideki in jenkiji radi prisvojili iranske zaloge nafte so naravnost butaste.
nuclear ::
Pol pol imas prav. Zelijo zamenjati rezim z necim, kar lahko kontrolirajo kot puppete Nemcijo, Francijo in podobne. S tem tudi pridobijo poceni nafto v iranu, kjer lahko natankas cel tank za $1.5
Strel455 ::
Fritz je izjavil:
Zakaj bi ga pa morali zasest? Saj bo naslednji predsednik itak Mossadov agent. 8-O
tomlin ::
To ni vojna, to je lekcija. Medtem ko Putler še vedno igra WW1 simulator z zarjavelimi cevmi in alkoholiki za topovsko hrano, drugi iz 1.000+ km s kirurško natančnostjo izklapljajo radarje, obrambo in živce sovražnika - brez da se sploh dvignejo z naslanjača.
Mest ti ni treba zravnati z zamljo. Samo tisti, ki nimajo ne pameti ne tehnologije, še vedno verjamejo, da se zmaga z ruševinami.
M. Friedman
Minutka.
Israeli 🇮🇱 planes now operating over Iran during the daylight.
156 / 255
