Forum » Strojna oprema » Matsonic
Matsonic
Dany ::
Zanima me do koliko podpira ta plošča procesorje. Model Matsonic MS8308EP!!
- premaknilo iz Pomoč in nasveti: bastadu ()
Tilen ::
Support Socket A AMD Duron/Athlon CPU up to 1.4 GHz and Palomino CPU up to 2600+
- spremenil: Tilen ()
StratOS ::
Manuals :
MS8308EP(266) ms8308ep266.zip
No za ostale je pa tukaj.
Na hitro :
Socket-462 Processor Support
♦ Supports AMD Athlon XP/Athlon/Duron processors
♦ Supports 200/266 MHz Front-Side Bus
Processors are automatically configured using firmware and a
synchronous Host/DRAM Clock Scheme.
Install A CPU :
This mainboard has a Socket-462 CPU socket for AMD K7
processors.
To ensure reliability, ensure that your processor has a
heatsink/cooling fan assembly.
Do not try to install a Socket-370/Socket-7 processor in the Socket-
462. A Socket-370/Socket-7 processor such as the PPGA Celeron,
FCPGA Pentium-III, Pentium-MMX, or the AMD K5/K6 does not
fit in the Socket-462.
The following list notes the processors that are currently supported
by this mainboard.
Athlon XP: 1500+, 1600+, 1700+, 1800+; FSB: 266 MHz
Athlon: 650 MHz~1.4 GHz, FSB: 200 MHz, 266 MHz
Duron: 550~850 MHz, FSB: 200 MHz
Na hitro :
Install A CPU :
processors.
by this mainboard.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
- spremenila: StratOS ()
| » | Qdi kinetiz 7b + Athlon 1800+Oddelek: Strojna oprema | 2320 (2127) | Blinder |
| » | integrirana grafičnaOddelek: Kaj kupiti | 1501 (1292) | tv6865 |
| » | ASUS ploščaOddelek: Pomoč in nasveti | 2185 (1917) | AngelOfDeath |
| » | Zbogom Socket AOddelek: Novice / Procesorji | 5002 (3877) | Azrael |
| » | socket-462Oddelek: Strojna oprema | 1092 (1035) | DjTonic |
