Forum » Pomoč in nasveti » Zajem slikena ATI TV WONDERJU
BC3 ::
Windows XP Tuner/Capture Software
ATI Multimedia Center 7.2
Posted November 27, 2001
The ATI Multimedia Center provides MPEG, AVI and CD Audio playback. Tuner/Capture functions are also offered on supported RADEON hardware (VIVO and ALL-IN-WONDER configurations).
povezava
povezava
-:| athlon x2 5000->phenom fx-5000@3G, vapor-x 4890, aeneon xtune |:-
~Panter~ ::
Hm, tam piše tole :
Do NOT use it for:
ATI TV WONDER
TV WONDER VE
TV WONDER USB Edition
Older ATI-TV tuners that attach to the graphics board with a ribbon cable.
A je kdo useen probou? A se splača dolvlečt tole stvar?
Do NOT use it for:
ATI TV WONDER
TV WONDER VE
BC3 ::
ups
sm spregledu da rabš za tv wonder
ATI-TV WONDER Windows XP Multimedia Center Software
ATI Multimedia Center 7.1
Posted July 5, 2001
The ATI Multimedia Center provides Tuner/Capture functions as well as MPEG, AVI, and CD Audio playback support.
,,i need help with multimedia center"
Posted July 5, 2001
BC3 ::
ATI Multimedia Center 7.5 Including DVD Player
Description: This unofficial version is the latest known release. Please consider this beta software. Download & use @ your own risk.
Added on: 13-Dec-2001 Downloads: 6695 Rating: 8.7 (7 Votes)
Rage3D Discussion Area > TV Wonder Forum > TV Related Support
- spremenilo: BC3 ()
uros ::
Jest mam Cyberlinkov Power vcr pa mi dela full uredu.
Lahko zajemem full resolucijo, sam morš met dost močn cpu cca 1 Ghz. Med na 1.7 xp ju dela ko šus.
Mam pa ati tv wonde ve
C00PER ::
Uros - ti meni nekaj povej....vidim da imaš TV Wonder VE na Xp-jih....z katerim programom sploh gledaš ti TV ? Jaz sem namestil vse gonilnike in dela vse, a ko nametim MMC zaženem TV, ni nikjer funkcije da bi skeniral kanale......reči mi kako rešim tole zadevico, plis !
uros ::
Jest mam gor une drajverje ki jih dobiš zreven mmc sam samo drajverje, ker uno sranje od multimedia centra pod XP-ji noče delat. Za tv gledat mam pa more tv je full good zadeva mau posrči po netu.
| » | Problemi z čisto novim računalnikom prosim pomočOddelek: Pomoč in nasveti | 2185 (1813) | nokia6310 |
| » | zanimivo - ATI TV wonderOddelek: Zvok in slika | 1388 (1079) | Snupy_II |
| » | ATI Multimedai center 7.1Oddelek: Pomoč in nasveti | 1303 (1104) | saleknd |
| » | ATI Multimedia Center 7.1Oddelek: Programska oprema | 1306 (1201) | |jebiveter| |
| » | ATI TV Wonder Win2kOddelek: Pomoč in nasveti | 1129 (1039) | mangaldar |
