temp direktorij v win95
tac ::
Kako nastavim temp direktorij v win95 ? Na c particiji nimam skor nic prostora, na d pa dovolj ? Torej moram nekako prepricat windowse da bi imeli to na d-ju. Set temp v autoexecu ne dela, al pa ne znam prav napisat ? :( . Za pomoc se zahvaljujem.
goba ::
Depending on which version of Windows you run, temporary files are usually stored in C:\WINDOWS\TEMP. This tweak shows how to move the location of the temporary file directory.
Open up AUTOEXEC.BAT with a text editor, it is normally found at C:\AUTOEXEC.BAT. If you're run Windows 9x it maybe possible to right-click the file in explorer and choose 'Edit'.
Add two new lines, or modify the existing lines if they are already there, as follows:
SET TEMP=[directory]
SET TMP=[directory]
e.g. SET TEMP=C:\GARBAGE
Save AUTOEXEC.BAT, create the directory entered above and reboot.
JAVA SDK - namestitev
Oddelek: Programiranje
122931 (2029) cobrica
seatools
202371 (2216) StratOS
MS-DOS Elektronček Blagajna
Oddelek: Programska oprema
183124 (2662) _vrag_
a je mozno prestaviti mapo temp???
111232 (1061) root987
Autoexec.bat
Oddelek: Operacijski sistemi
122273 (2055) alien-w
