težave z reset cmos (pravi jumper) pomoč prosim
the_game ::
no imam težavo in nevem kateri jumper je pravi za reset biosa
imam plato shuttle mv43v spodaj na sliki
http://shrani.si/?mv43vv73oy74.jpg][img...
  • spremenil: the_game ()
amigo_no1 ::
Odstrani baterijco za minuto (spodaj levo).
Drugače pa RTFM !
  • spremenilo: amigo_no1 ()
MaX ::
Pravi jumper je skoraj vedno tisti, kateri, kateri je najbližje baterije. Poglej zraven jumperja, običajno kaj piše zraven.
StratOS ::
RTFM, mislim da je to najboljša informacija
Preglej jumper Clear CMOS JP-1 stran 11 pdf-ja.
Za Clear CMOS si preglej stran 28.
Na hitro :
Clear CMOS Setting (JP1)
JP1 is used to clear CMOS data. Clearing CMOS will result in the permanently
erasing previous system configuration settings and the restoring original (factory-
set) system settings.
Pin 1-2 (Default)
Pin 2-3 (Clear CMOS)
Step 1. Turn off the system power (PC-> Off).
Step 2. Remove ATX Power cable from ATX Power connector.
Step 3. Remove jumper cap from JBAT1 pins 1-2.
Step 4. Place the jumper cap on JBAT1 pin 2-3 for a few seconds.
Step 5. Return the jumper cap to pin 1-2.
Step 6. Plug ATX Power cable into ATX Power connector.
Step 7. Turn on the system power (PC-> On).
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
the_game ::
TNX
Sm prestavo jumper pa se je bios resetiral in dela vse normalno.
Test matičnih ploŠč - kje so clr cmos zobci
164601 (4304) Siddh
računalnik se ne boota
81599 (1498) IvoJan
Dva računalnika na izbiro
121745 (1588) opeter
Reset biosa na Hp
232457 (2284) RiNC
"flashanje" BIOS-ov
372328 (1903) cultko
