Vsftp
Vsftp
marpol ::
Imam problem s postavitvijo ftp strežnika na rh 9.0 lokalno mi ftp deluje ok odzunaj pa ne na routerju sem naredil preusmeritve portov skonfiguriral vsftp.conf ki ki izgleda tako kot je navedeno spodaj za vsako pomoč vam bom zelo hvaležen.
# Example config file /etc/vsftpd.conf
# The default compiled in settings are very paranoid. This sample file
# loosens things up a bit, to make the ftp daemon more usable.
# Allow anonymous FTP?
anonymous_enable=NO
# Uncomment this to allow local users to log in.
local_enable=YES
# Uncomment this to enable any form of FTP write command.
write_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
local_umask=022
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
# Uncomment this if you want the anonymous FTP user to be able to create
# new directories.
#anon_mkdir_write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
#chown_uploads=YES
#chown_username=whoever
# You may override where the log file goes if you like. The default is shown
# below.
#xferlog_file=/var/log/vsftpd.log
# If you want, you can have your log file in standard ftpd xferlog format
xferlog_std_format=YES
# You may change the default value for timing out an idle session.
idle_session_timeout=2048
# You may change the default value for timing out a data connection.
data_connection_timeout=1024
# It is recommended that you define on your system a unique user which the
# ftp server can use as a totally isolated and unprivileged user.
#nopriv_user=ftpsecure
# Enable this and the server will recognise asynchronous ABOR requests. Not
# recommended for security (the code is non-trivial). Not enabling it,
# however, may confuse older FTP clients.
#async_abor_enable=YES
# By default the server will pretend to allow ASCII mode but in fact ignore
# the request. Turn on the below options to have the server actually do ASCII
# mangling on files when in ASCII mode.
# Beware that turning on ascii_download_enable enables malicious remote parties
# to consume your I/O resources, by issuing the command "SIZE /big/file" in
# ASCII mode.
# These ASCII options are split into upload and download because you may wish
# to enable ASCII uploads (to prevent uploaded scripts etc. from breaking),
# without the DoS risk of SIZE and ASCII downloads. ASCII mangling should be
# on the client anyway..
ascii_upload_enable=YES
ascii_download_enable=YES
# You may fully customise the login banner string:
#ftpd_banner=Welcome to blah FTP service.
# You may specify a file of disallowed anonymous e-mail addresses. Apparently
# useful for combatting certain DoS attacks.
#deny_email_enable=YES
# (default follows)
#banned_email_file=/etc/vsftpd.banned_emails
# You may specify an explicit list of local users to chroot() to their home
# directory. If chroot_local_user is YES, then this list becomes a list of
# users to NOT chroot().
#chroot_list_enable=YES
# (default follows)
#chroot_list_file=/etc/vsftpd.chroot_list
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
pam_service_name=vsftpd
userlist_enable=YES
#enable for standalone mode
listen=YES
tcp_wrappers=YES
trnvpeti ::
problem nimas na serverju
verjetno nimas ok na routerju
povej kako si preusmeril porte na ftp?
kaksen router imas
arjan_t ::
imaš mogoče firewall na te mašini?
'FireSTORM' ::
ni router
to sem tudi jaz mislil
ker sem mel ta vsftp
pa sem router odstranil pa še vedno isto blo
nakar sem to lepo pobrisal in inštaliral proftp server
sedaj dela bp
Those penguins.... They sure aint normal....
marpol ::
Na serverju je izklopljen firewall port 20 in 21 pa sta preusmerjena na ip od strežnika
Ni mi jasno kaj narediti aja router je level one.
trnvpeti ::
ponavadi mora imeti router podporo za transparent ftp
pod linuxom moras imeti poseben modul za forward ftp porta
mislim da imajo tudi routerji
pac sprobaj dati server direkt na adsl,kabel
pa probaj ftp
ce dela, prek routerja pa ne
potem zacni raziskovati,kako to router podpira
ce tudi direkt server ne deluje, potem pac nagruntaj vsftp
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187286 (7145) ManDriver
Kratek uvod v FreeBSD (strani: 1 2 3 4 … 8 9 10 11 )
Oddelek: Operacijski sistemi
51471759 (35497) Prospekt
FreeBSD z ADSL kot domači router
72732 (2633) moj_nick
Gentoo setup problem
252210 (2034) G2
Linux / ATI Radeon / problem z driverji
132225 (2042) ahac
