[Naloga][C++] MFC HOOKPROC pretvarjanje
]Fusion[ ::
Imam za šolo eno nalogo in dobivam neki čudn error v VS2005. dobim error:
Error 1 error C2440: 'type cast' : cannot convert from 'overloaded-function' to 'HOOKPROC'
Če mogoče ima kdo idejo kje je problem se bi priporočal :)
Pa še koda:
#include "stdafx.h"
#include "Vaja3_dll.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#endif
// CVaja3_dllApp
BEGIN_MESSAGE_MAP(CVaja3_dllApp, CWinApp)
END_MESSAGE_MAP()
// CVaja3_dllApp construction
CVaja3_dllApp::CVaja3_dllApp()
	// TODO: add construction code here,
	// Place all significant initialization in InitInstance
// The one and only CVaja3_dllApp object
CVaja3_dllApp theApp;
// CVaja3_dllApp initialization
BOOL CVaja3_dllApp::InitInstance()
	AFX_MANAGE_STATE(AfxGetStaticModuleState( ));
	ghInstance = AfxGetInstanceHandle();
	CWinApp::InitInstance();
	return TRUE;
LRESULT _declspec(dllexport) _stdcall CVaja3_dllApp::MouseProc(int nCode, WPARAM wParam, LPARAM lParam)
	//koda za prestrezanje
void _declspec(dllexport) CVaja3_dllApp::InstallMouseHook(HWND hWnd)
	ghWndMain = hWnd;
	HOOKPROC lpfn =(HOOKPROC) MouseProc;	            //<---- tu javi napako
	ghMouseHook=SetWindowsHookEx(WM_MOUSE, lpfn, ghInstance, NULL);
void _declspec(dllexport) CVaja3_dllApp::DeInstallMouseHook( )
	::UnhookWindowsHookEx(ghMouseHook);
Če rabite še .h fajl al pa katerega drugega rečte.
P.S.: takoj v naslednji vrstici tudi ne prepozna WM_MOUSE če še mogoče to kdo ve kaj bi lahko blo :)
"I am not an animal! I am a human being! I... am... a man!" - John Merrick
  • spremenilo: CCfly ()
yeti ::
Ni se mi dalo preverjat v msdn, samo na brzino;
static LRESULT _declspec(dllexport) _stdcall CVaja3_dllApp::MouseProc(int nCode, WPARAM wParam, LPARAM lParam)
ghWndMain = hWnd;
HOOKPROC lpfn =(HOOKPROC) &MouseProc;
Function POINTER filaš!!
[c#] Vprašanje glede release verzije aplikacije
Oddelek: Programiranje
51987 (1811) Ericssony
Tezava pri instanciranju class-a
61797 (1668) KernelPanic
Win32 API in C++
131962 (1833) Monster
OpenGL orr v ansi c
122167 (1955) igor12
Odpiranje dat.exe v VB
123851 (3644) webblod
