Diagnostic tool za Maxtor
AngelOfDeath ::
Rabil bi diagnostično orodje za Maxtor DiamondMax 10 ki podpira Via kt600 ali pa nf4
Ve kdo kje kaj takega dobit ?
edit: Slovnica
harvey ::
Na njihovi uradni spletni strani www.maxtor.com pod software downloads. Tam imaš diagnostično orodje PoweMax.
The PowerMax utility is designed to perform diagnostic read/write verifications on Maxtor and Quantum hard drives. These tests will determine hard drive integrity. The PowerMax utility is effective on all ATA (IDE) hard drives with a capacity greater than or equal to 500 MB. Maxtor recommends the use of this utility for troubleshooting potential hard drive problems.
AngelOfDeath ::
Mogoče bi bilo dobro da še enkrat prebereš kar piše na Maxtorjevi strani, še posebej ta del:
Note: PowerMax v 4.21 will not detect ATA or SATA hard disks connected to embedded or add in RAID controllers, NVIDIA Force 4, VIA KT 600 and KT800 chipsets. If the hard disk is connected to an unsupported controller, it will have to be moved to an alternate system, or controller for diagnosis. Please check the PowerMax download page periodically for updates. Beginning September 1st 2006 all versions of PowerMax prior to v4.23 will no longer be supported. Maxtor recommends that you update to version 4.23 before testing your hard disk.
torej če nimaš Intelovega čipseta se lahko s tem Powermaxom je***
edit: Slovnica
NTLDR is missing
328695 (7843) kreki
Diagnostično orodje za WD
Oddelek: Programska oprema
145037 (4897) clovk
Reklamacija diska maxtor 80GB in zajebancija s strani prodajalca
365034 (300) SepoX
Secondary master drive fails
81370 (1303) carota
SATA neverjetno počasen
142561 (2297) Pyr0Beast
