Forum » Programska oprema » Winxp messenger in Office Xp slo čekiranje
Dalmatinc ::
Prosim za pomoč.
Kako se v XP-jih izbriše messengerja. Čist. Sem že enkrat videl pa ne najdem zgleda da ne pokaže več do tja.
Please povejte
Pa a je kako v ang XP officih naštimaš da popravla slovenski tekst k skoz javlja da nima datotek.
HVALA NAJLEPŠA
sem dons dal gor win 98 pa sem videl da brez XP mi živeti ni
Please povejte
HVALA NAJLEPŠA
[t502] ::
Probaj tole:
Open windows explorer and goto the folder "C:\windows\inf\" and open the
file called sysoc.inf.
Find the following line in that file:
msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,hide,7
and now remove the word "hide", so the line looks like:
msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,,7
now save it and close the file.
Now once you have done that go into the control panel and then goto "Add and remove programs". Then select the "Add remove windows components" button which is located down the left side of the window. In the dialog scroll down to the bottom and untick Messenger. Hit "ok", and we have lift off.
alpa ce ti vedno ne gre pa tole
| » | Win Messenger ne da miru!!!!!!!!!Oddelek: Programska oprema | 1533 (1316) | andper |
| » | Odstranitev Windows MessengerjaOddelek: Pomoč in nasveti | 2091 (1934) | alkoo |
| » | messenger in zivcni zlom!!!!Oddelek: Programska oprema | 2181 (1699) | KTr1sk |
| » | Win XP - messengerOddelek: Programska oprema | 1578 (1430) | IgiS |
| » | zoprn windows messangerOddelek: Pomoč in nasveti | 1703 (1588) | Ikarus |
